WTB long travel kit
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by bruth, Jun 17, 2012.
  1. Jun 17, 2012 at 1:04 AM
    bruth
    bruth [OP] Well-Known Member
    Brian
    Alamo ca
    2000 access cab 4x4 Tacoma
    Total chaos is currently shipping
    :DHey guys i want to get a long travel kit... not sure which kit i want to go with but if anyone is in cali or close to cali that is selling an lt kit please post! not sure if i want a used one but if i find the right one i will def purchase!
  2. Jun 17, 2012 at 1:21 AM
    bruth
    Brian
    Alamo ca
    ... and to add would it be cost effective to buy ucas and lcas seperate and all components and kinda shop around for specific parts for the front end or is it better just to nut up and get a tc or camburg lt kit?!:confused:
  3. Jun 17, 2012 at 1:25 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    you should get a kit not mix and match. all kits are different lengths and use different geometry to make work properly so use only parts from each together. and good luck finding a used LT kit they come up very rarely and when they do they go fast
  4. Jun 17, 2012 at 1:31 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    and you might have better luck posting in the long travel sub section
  5. Jun 17, 2012 at 1:41 AM
    bruth
    Brian
    Alamo ca
    thanks guys ya ive been in the lt forum im not to experienced with forums and all but i LOVE tw its amazing and ya thanks i think im going camburg but i just saw a few guys with camburg uca's and tc lca's and it looked like it worked good. Also is it worth going bypass?
  6. Jun 17, 2012 at 1:46 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    what kind of offroading do you door want to do? i know its been said a million times before in other forums but its not simply bolting a front LT kit and calling it a day expect your truck to be kind of a money pit, or opening a can of worms. the front kit comes first usually cause its cheaper. then rear leafs or links. then roll cage. then you will want to upgrade your spindles and maybe convert to 12" coils up front which will require an engine cage. my suggestion is do a ton of research on what you want to do. anyone will tell you to get the rear done first which is smart. and get a roll cage it will save your life.
  7. Jun 17, 2012 at 1:47 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    im defintely not trying to steer you away! just want to make sure you know what it entails
  8. Jun 18, 2012 at 11:33 PM
    bruth
    Brian
    Alamo ca
    Hey so i have a friend of my buddy that worked at a well known lift kit company and he said he could extend stock lca's 2 inches and it would work with say camburg or tc uca's and then all the rest he can help me out with... has anyone heard of fabricatin OEM LCA'S to extend them cause he has done it before on a ranger and said it worked great. what feedback do you guys have?
  9. Jun 18, 2012 at 11:40 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Sounds like serious trouble if it's not done correctly not to mention a stock lca isn't beefy enough to beat on it in an LT sense. Not worth cutting that corner. To save you a few bucks. You'll probably break more shit if your lca snaps than the proper lt lca
  10. Jun 19, 2012 at 12:02 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    OP how much are you looking to spend?
  11. Jun 19, 2012 at 12:41 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    does he own a black ford explorer? just wondering..
  12. Jun 19, 2012 at 12:46 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    With steel plate flared fenders? Lol
  13. Jun 19, 2012 at 4:15 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Read the tacked LT threads several times, sleep on it, and go from there.
  14. Jun 19, 2012 at 6:20 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  15. Jun 19, 2012 at 7:29 AM
    linked2002
    linked2002 Well-Known Member
    san diego
    02 tacoma, 3 linked, 6 over custom arms, cage
    links, custom 6 over arms, full 1.75 d.o.m. cage, 35 gallon cell, etc
    wait... cut stock lowers?! i want a set!!! if your boy can get those for you, ill trade you my custom 6 over upper and lowers for the cut and extended stockers!
  16. Jun 19, 2012 at 7:49 AM
    MonkeyProof
    SoCal- SGV
    This thread delivers
    :popcorn:
  17. Jun 19, 2012 at 7:53 AM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    :boom:
  18. Jun 19, 2012 at 7:59 AM
    linked2002
    san diego
    and please tell me your not talking about the red ford ranger that drove around with hack fab cut and extended lowers in el cajon. here are a few reasons:
    1) working at 4 wheel parts installing lift kits does not mean you automatically know what your doing when it comes to BUILDING suspension. bolting something on vs. actually start to finish fabrication are two very different animals
    2) dont be a retard and end up killing someone with your sketchy ass truck. do it right the first time or dont do it at all. this sport isnt here for the people looking to cut corners... if you want to cut corners.... look into possibly becoming a mason installer.
  19. Jun 19, 2012 at 9:10 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Seems legit
  20. Jun 19, 2012 at 9:14 AM
    MonkeyProof
    SoCal- SGV
    I remember reading that thread..but then again..I think everyone on the internet has seen that build thread . Its been linked in just about every offroad truck forum imaginable lol
