WTB: Looking for 2009-2011 Overhead Console with Temp/Compass
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 709GADE, Aug 10, 2011.
  1. Aug 10, 2011 at 9:38 AM
    709GADE
    709GADE [OP] Well-Known Member
    '09 Toyota Tacoma 4X4 SR5 DC LB - Pyrite Mica
    Toyota aluminium side steps, Toyota door sill protectors Extang trifecta tonneau cover, U-Haul Class 3 hitch, Black Weathertech's, Front mudflaps trimmed 4", OEM Fog Lights, WeatherTech Bug Deflector, 13" Stubby antenna, TRD Skid Plate, ScanGaugeII, Carriage Works Billet Grille, Plasti Dipped overhead temp/compass console, LT265/75/16 Duratrac's LR C
    title says it all...Thanks
  2. Aug 31, 2011 at 9:22 AM
    709GADE
  3. Aug 31, 2011 at 1:45 PM
    Zilkerpaddle
    Zilkerpaddle Member
    Texas
    10DCsr54x4
    None yet
    I have the same truck (different exterior color).
    if you find one it should be plug and play. temp probe and all wiring should all be there.
  4. Aug 31, 2011 at 1:51 PM
    709GADE
    That's true...Looking for any color console (grey or tan) :D
  5. Aug 31, 2011 at 6:29 PM
    bizjettech
    bizjettech Well-Known Member
    San Antonio, TX
    2013 MGM DCSB 4x4 TRD OR
    undercover flex bed cover
  6. Aug 31, 2011 at 11:49 PM
    supriseaztacoma
    supriseaztacoma AZ it is a "dry heat"
    Aaron
    Surprise
    15 Tundra Crew Cab
    guys search the fix for those, I had mine go out and fixed it with no issues since! Was easy!~
  7. Sep 1, 2011 at 6:00 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    FYI, you won't find a stock tan temp/comp console as they only came in the TRD packages and tan wasn't an interior color option on those. If you find a tan one, it's been modified (like I have done).
  8. Sep 1, 2011 at 6:02 AM
    709GADE
    Do you have any pics? How did you mod it?
  9. Sep 1, 2011 at 7:01 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I just did it this last weekend, and haven't taken any pics, so I hadn't posted anything,,, to avoid the "pics or it didn't happen" posts :D
    But what I did was; I found (was offered) a grey temp/comp console for a reasonable price, I took the grey console and removed the temp/comp unit/plastic surround (more on this below), and placed it into the tan console.
    The temp/comp unit's plastic surround is attached to the console using melted plastic tabs and rings. You need to heat those spots and manipulate the plastic so that you can remove the unit from the new console, remove the garage door bin from the old console (heat and plastic again), then place the unit into the old console. Then reheat and bend the plastic tabs and rings back down.
    I found a "reasonable" color matched can of Fusion paint at Wally world. It's just a bit lighter, but close enough for me. If you want a total match on the entire console, I think you'll need to paint the entire console, or find some way to get a can of the tan interior's color matched paint.
    I removed the unit from the console (remove the unit from the plastic with 3 screws), masked off the unit's plastic surround from the console and painted it. NOTE, much easier to remove the unit/surround from the new console, remove the unit from the plastic surround, paint the plastic surround, THEN put the plastic surround/unit into the old console. I got in a hurry to see it working and didn't want to have to trip over to Wally world for a can of paint first.
    Also, for heat, I'd read that using a soldering iron works and was going to use that, but got too lazy to untangle the extension cord, and decided to use a propane torch... It did work, but was like using a 20 lb sledge hammer to pound a nail. I would recommend a soldering iron with a spade-like tip on it.
  10. Sep 1, 2011 at 7:10 AM
    709GADE
    Thanks for posting...
  11. Sep 2, 2011 at 3:12 PM
    SGT Taco
    SGT Taco Disco Disco...
    Scott
    Rio Rancho Nm.
    R.I.P. 2007 TRD... Now a Land Rover Disco II
    Wife rolled it 3x mod...
    are the 2009-2011 different than the 2007? i have one that i bought at the stealership years ago before i know how easy it was to fix... if not let me know i will sell it. if you have a part number let me know and i will check mine to see if they are the same. P.M. me
  12. Sep 2, 2011 at 3:55 PM
    SGT Taco
    Scott
    Rio Rancho Nm.
    so i just talked to the Earnheart Toyota in mesa az, and the parts supervisor said that they are the same part, just with different part numbers for when they started soldering the board differently. so if anyone is interested pm me and we can work something out. I have re-soldered both the 510 resisters and the three 720 resisters on this one for good measure and all works great!
  13. Sep 2, 2011 at 5:53 PM
    SGT Taco
    Scott
    Rio Rancho Nm.
    let me correct my self. i did some more looking into this and other people are correct, the displays are different starting 2009... they changed from a 5 wire to a 6 wire. the temp sensor is wired into the A.C. unit for some reason and then sent to the overhead.... sorry for the mix up.
