WTB Lower Control Arms
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Kwikvette, May 17, 2019 at 2:15 PM.
  1. May 17, 2019 at 2:15 PM
    Kwikvette
    Kwikvette [OP] Well-Known Member
    Monterey County, CA
    2001 Tacoma Prerunner TRD
    Fox 2.5 Coilovers Fox 2.0 Smooth bodies OME Dakar leafs Trail Gear Rear Bumper
    Looking for both left and right lower control arms for my 2001 Prerunner Auto
    Trying to minimize vehicle down time by installing new bushings on the extra LCA and replacing all at once.
    Located in Central CA (Monterey County)
  2. May 17, 2019 at 2:19 PM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    Valve Caps, 2 stickers, bent radio antenna.
  3. May 17, 2019 at 2:26 PM
    Kwikvette
    Monterey County, CA
    May just have to do that.
    Unsure about the integrity of aftermarket vs factory (even if they're used/old).
  4. May 17, 2019 at 8:40 PM
    Tour991
    Tour991 Well-Known Member
    James
    South Lake Tahoe
    97 2/4wd, 2014 Crew cab 4x4
    I have a driver side. I'm up in South lake Tahoe
  5. May 17, 2019 at 9:38 PM
    04Pre_Runner
    Andrew
    San Angelo, Texas
    2004 DC Tacoma SR5 4WD V6
    OME Suspension, 4WD Conversion, ARB Bumper
    In my experience aftermarket has been poor quality. I'm running a set of duralast lowers and the bushings in them are already shot and very noisy after ~12,000 miles. Swapping back to OEM Toyota arms and debating on pressing in Whiteline Polyurethane Bushings or keeping them stock. Edit: Just saw you'd only be swapping them on for a short amount of time. Then aftermarket would be fine but expensive.
  6. May 17, 2019 at 9:41 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Just put new bushings in your old ones. It takes less then 30 minutes. Freeze the new bushings the night before. Pop the old ones out with a bottle jack and some heat. Push in the new ones. I just did mine two months ago and it really is that simple.
  7. May 17, 2019 at 10:23 PM
    Kwikvette
    Monterey County, CA
    I've found that nothing is just that easy on an older vehicle.
    There are always some hiccups and if I'm going to replace my bushings, it'd be on my current ones. However, I'd want my truck drivable while I replace the bushings.
    Just not sure if I should get used ones to put new bushings in or new ones and use them as is.
  8. May 17, 2019 at 10:39 PM
    Dalandser
    Dalandser ¡Me Gustan Las Taco-mas!
    Anthony
    Downey, LB
    Empty Wallet Mod
    I've got a pair in LA
