WTB OEM CVs
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by nagorb, Oct 14, 2013.
  1. Oct 14, 2013 at 8:20 PM
    nagorb
    nagorb [OP] Temp mod
    Auburn Alabama
    2001 dbl cab 4x4
    Looking to buy a set of OEM CV shafts. Let me know what ya got and how much you want!
    Thanks
  2. Oct 15, 2013 at 10:04 PM
    nagorb
    Auburn Alabama
    2001 dbl cab 4x4
  3. Oct 15, 2013 at 10:12 PM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    Don't get OEM if you plan on lifting your truck. I recently put new CV axles in my truck because the boots on the OEMs ripped. So I got aftermarket axles with neoprene boots. They will last longer. Google and you will eventually find them.
  4. Oct 15, 2013 at 10:16 PM
    nagorb
    Auburn Alabama
    2001 dbl cab 4x4
    The boots might but the axles won't, too many stories of broken aftermarket CVs. My fins aren't even touching just old so they finally split. I plan on getting a set of the high clearance, or whatever they're called, boots to install before replacing.
  5. Oct 15, 2013 at 10:18 PM
    ToyotaKTMracing
    Shay
    West Virginia
    Oh, okay. Well I can still recommend neoprene boots :thumbsup: But if you don't lift your truck, you can stick with OEM.
  6. Oct 15, 2013 at 10:21 PM
    nagorb
    Auburn Alabama
    2001 dbl cab 4x4
    I'll look into the neoprene for the first gen, thanks. I'ts lifted already but only about 1.5 in
  7. Oct 15, 2013 at 10:22 PM
    ToyotaKTMracing
    Shay
    West Virginia
    That's not bad. The angle shouldn't be much difference from stock. They should be fine. I'm about 3" of lift in the front on my truck so mine are pretty angled.
  8. Oct 15, 2013 at 10:23 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Just go to your local auto parts store and buy the refabbed oems with lifetime replacements, thats what I did
  9. Oct 15, 2013 at 10:25 PM
    nagorb
    Auburn Alabama
    2001 dbl cab 4x4
    The ribs on mine aren't even touching but I figure if I'm already swapping them I might as well put better boots on.
    From what I've been reading online they aren't all OEM.
  10. Oct 15, 2013 at 10:25 PM
    ToyotaKTMracing
    Shay
    West Virginia
    This is good too. Cheaper and just as good as new.
  11. Oct 15, 2013 at 10:32 PM
    bellassaiw10
    Currituck NC
    Who cares if theyre good... you get free replacements lol
  12. Oct 15, 2013 at 10:36 PM
    ToyotaKTMracing
    Shay
    West Virginia
    I meant the idea, but that too. lol
  13. Oct 15, 2013 at 10:42 PM
    nagorb
    Auburn Alabama
    2001 dbl cab 4x4
    For one they have shity boots, it's no fun doing trail repairs, it happens but I try to minimize it, not to mention from what i've seen aftermarket ones tend to break at the splines which isn't easy to remove. Also I don't want to have to pay the core charge on both cause my old ones will be spares, and they stop honoring the replacements after a few times.
  14. Oct 15, 2013 at 10:50 PM
    bellassaiw10
    Currituck NC
    Ive broken 2 OEM ones and 1 aftermarket, if you break boots that often youve got other problems... GL finding anyone willing to sell OEM ones though
  15. Oct 15, 2013 at 10:54 PM
    nagorb
    Auburn Alabama
    2001 dbl cab 4x4
    I'm not worried about breaking boots;)
  16. Oct 16, 2013 at 7:29 AM
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    I've been through probably 7 cv axles (front ARB locker eats them). Broke my OEM's and replaced with advanced auto cv's. Who care's if they break. 30 min job, free replacement is the tits. Especially when you know it's bound to happen. You gotta pay to plan man. If you're just rolling in cash and want to replace with OEM's every time go for it.
    FWIW, I've never had a cv brake at the shaft inside the diff. They always bust the cage or snap in the center shaft somewhere.
  17. Oct 16, 2013 at 9:21 AM
    nagorb
    Auburn Alabama
    2001 dbl cab 4x4
    I thinki made my position clear, i didn't come here for advice.
  18. Oct 17, 2013 at 6:52 PM
    nagorb
    Auburn Alabama
    2001 dbl cab 4x4
  19. Oct 17, 2013 at 7:02 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    Have you looked at the cvj remanufactured oem ones? That's what I'm planning on getting to replace my current ones.
  20. Oct 17, 2013 at 8:58 PM
    nagorb
    Auburn Alabama
    2001 dbl cab 4x4
    Yeah thats an option but I want to keep my current ones as spares so I would end up paying I think around $200 per. For that I would just rebuild my current ones and get a napa one for a spare. What I want is a spare set so I can rebuild them when I have time.
