WTB: Roof rack!
Discussion in 'Buy / Sell / Trade' started by eddyb22, May 18, 2012.
  1. May 18, 2012 at 7:36 AM
    eddyb22
    eddyb22 [OP] Well-Known Member
    I would like to buy a roof rack if anyone has one PM me thanks!
  2. May 18, 2012 at 7:37 AM
    eddyb22
    Does a roof rack even fit an AC? i just thought about that..
  3. May 18, 2012 at 7:37 AM
    757 Taco
    757 Taco StormTrooper
    Tyler
    757
    2012 DCLB TRD Sport 4x4 Super White
    - Digital Fit WeatherTechs - Recovery Hitch Shackle - Tinted Windows 20% Front, 5% Rear Window - White 48-LED Dome Light - Two 12-LED Map Lights - Sylvania Silverstar Ultra Headlight Bulbs - LED License Plate Bulbs -20" LED Lightbar - 886 Reverse Light Mod - FogLight Anytime Mod - AFE ProDry S Drop-In Air Filter - OME 885x Coils w/ Bilstein 5100's @ 0" - Rear Bilstein 5100's - Wheeler 1.5" Progressive AAL - TRD License Plate Brackets - Front Recovery Shackle - Black LED Tail Lights - Toyota Bed Mat - LED Third Brake Lights - Sockmonkey Bedside Decals - 285/75/16 Goodyear Wrangler Duratracs - Procomp 7089's - Rear Diff Breather Mod - FlyzEye V1 - Grillcraft w/ FJ Emblem - Removed Sway Bar - TRD Auto Shift Knob - TRD Offroad Transmission Skid - Hose Clamp Mod
  4. May 18, 2012 at 7:42 AM
    eddyb22
    what does sub'd mean?
  5. May 18, 2012 at 7:49 AM
    757 Taco
    Tyler
    757
    subscribed to the thread. i want a rack too!!
  6. May 18, 2012 at 7:49 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    The OEM roof rack will NOT fit an access cab, they're made for double cabs only. You can put a Thule or Yakima roof rack on your access cab though since they attach differently. Thule and Yakima are also rated for more weight but the cross bars don't 'stow away' like the OEM rack. If you really want an OEM rack, someone did cut one down and made it fit an access cab but the cross bars wouldn't stow away and it requires hacking up the roof rack quite a bit.
    Means he's subscribed to this thread so he'll know when someone responds.
  7. May 18, 2012 at 7:52 AM
    Tuhkohmuh
    Tuhkohmuh Well-Known Member
    Brent
    Gamecock Country
    06 TRD Sport Longbed CrewCab
    Avid light bar, TRD skid plate, Thin Lip Satoshi, 2 Hella black Magic 1000 lamps behind Grill, OEM Roof Rack, Predator Step-ups, OEM bed bars with Yakima Load Warrior Basket, Blacked out emblems all around.
    No the OEM roof rack does not fit AC. I have seen people cut them to fit but then you can't store the rails which is the best feature. If you want a rack may have to go a different route. Good Luck!
  8. May 18, 2012 at 10:32 AM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    I can make a roof rack to fit double cabs. I actually have 2 for sale now. Access cabs don't have the factory rack locations and holes would need to be drilled into the roof. If you want, I can also build a chase rack. It will bolt into the bed bolts, and still hang over the roof, just won't attach to roof. PM if interested! :D
  9. May 18, 2012 at 1:09 PM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    I'm interested.... need one pretty quick.
  10. May 18, 2012 at 1:42 PM
    DWreck
    Derek
    Las Vegas, NV
  11. May 18, 2012 at 5:52 PM
    Techoma
    Alta Mesa, AZ
  12. May 18, 2012 at 8:37 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Ya the cut down rack for AC is quite a bit if work. If you don't want a project, go for Thule or Yakima.
    I do like the final look though:
    [​IMG][​IMG]
  13. May 18, 2012 at 9:11 PM
    Bradpad
    Bradpad Well-Known Member
    Brad
    MASS
    07 SR5 Access Cab V6 4x4
    K&N polished intake QTP electronic exhaust cutout
    i made this for my access cab, has 4 mounts that each have 2 , 1/4 inch holes for bolts that go through the roof and a nut tightened from the underside (under headliner). i could build you one to the style of your liking :D
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/215821-custom-roof-basket-access-cab-build-8.html
    ^my build thread for the rack
    pic one is how she sits, pic 2 is the mounts before the welds were cleaned up and painted, i sprayed the whole rack with bedliner spray to keep stuff up there from sliding around
  14. May 21, 2012 at 9:40 AM
    DWreck
    Derek
    Las Vegas, NV
    I'll check shipping today. It does bolt to existing locations. Are you interested in #1 or #2?
  15. May 21, 2012 at 10:41 AM
    big dog
    big dog Hug balls bitch
    Las Vegas
    03 SR5 TRD 4X4
    OME 3" k&n cai magnaflow muffler all pro front bumper 4x innovations rock sliders moto metal wheels with 33" Bridgestone dueler revo 2 AT tires
    Hay Derek do I get a finders fee LOL
  16. May 21, 2012 at 12:02 PM
    Techoma
    Alta Mesa, AZ
    #2. 23452 (VA), 91950 (CA) or 76092 (TX)
    If we can work shipping out... I'm in!!!! If I don't buy this from you... I'm tossing in the towel and buying the OEM tomorrow.
  17. May 21, 2012 at 1:16 PM
    DWreck
    Derek
    Las Vegas, NV
    I'll get back to you. I'll find out about shipping now.
