WTB set of OEM tail lights
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by 45acp, Feb 22, 2011.
  1. Feb 22, 2011 at 8:58 AM
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Someone backed into my truck and took out one of the aftermarket lights. I'd rather have OEM anyway, so I'm looking for a set.
    ETA:
    Still looking! The pair that I purchased (pictured farther down in this thread) are are apparently only usable on '95.5-'00. I need a pair of '01-'04 tail lights ASAP!
    When I can locate the correct pair, the older '95.5-'00 pair will become available.
  2. Feb 22, 2011 at 11:25 AM
    IamHimeros
    IamHimeros Well-Known Member
    I have a set off a 2000 Tacoma, so they arent identical to what you have but I will sell them for cheap
  3. Feb 22, 2011 at 11:51 AM
    S-Runner '01
    S-Runner '01 Elderly Gentleman - Junior Member
    Jerry
    Yakima "the Palm Springs of Central Washington"
    BSP '01 S-Runner
    Garmin 260W - GPS Scanguage II K&N FIPK Kit Delta Low Profile Toolbox Fumoto Oil Drain Valve New Toyota Front Mats B&M Short Throw shifter New Tokico Gas Shocks Compustar Anti Theft Alarm System Redline Elite Hood Struts Phase Linear DVD/MP3/CD Player Professionally Detailed
    How much is "for cheap?"
  4. Feb 22, 2011 at 12:38 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    aren't identical to the aftermarket ones I have or the ones I need? If you mean the latter, do they still fit an '04?
  5. Feb 22, 2011 at 4:09 PM
    IamHimeros
    This is his WTB thread, feel free to PM me if you would like information
    I was referring to them not being identical in style to the OEM tail lights for a 01-04 Tacoma. Below is a picture of my truck with the driver's side one being the 01-04 and the passenger side being the OEM 98-00 tail light (in which I am offering up). The owner before me put the black pieces on, they are easily removed because it is only double sided tape holding it on. I never removed the covers because I wanted the 01-04 OEM tail lights. They are complete, functional taillights in very good condition. And Yes, they will fit your truck without any modifications.
  6. Feb 22, 2011 at 9:52 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    IamHimeros How much would you sell those for?
  7. Feb 23, 2011 at 7:03 AM
    IamHimeros
    They were sold to the OP
  8. Mar 9, 2011 at 1:13 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Still looking! '01-'04 only!
    :annoyed:
  9. Mar 9, 2011 at 2:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Just curious, and don't want to thread just but.....
    How are the 01-04 tail light assemblies different from the earlier (96-00) versions? Why don't they work?
  10. Mar 17, 2011 at 6:42 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Still looking :goingcrazy:
  11. Mar 18, 2011 at 9:26 PM
    OmahaStylee
    OmahaStylee Beating Anorexia since 1976
    Omaha, NE
    01 DC TRD
    FRONT: Toytec CO's & diff drop BACK: AllPro standard leaf kit with Bilsteins and axle shims
    Take a look at the pic in IamHimeros's post above...
    you can see that the upper, middle & lower 3 portions of the tail light on the driver side bubble outwards.
    95-00 tail lights are a flat surface from top to bottom.
    I can't speak for "why don't they work", they might or might not - if they DO it might just be a personal preference
