WTB: Shackle hitch
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 09Tacomania, Jul 10, 2013.
  1. Jul 12, 2013 at 2:14 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    x2
    No problems with several tugs at Pismo.
  2. Jul 12, 2013 at 3:13 AM
    09Tacomania
    09Tacomania [OP] Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    Thanks to Rob, found me an OEM one off an 08.
  3. Jul 12, 2013 at 4:17 AM
    RiverBoyTRD
    RiverBoyTRD Well-Known Member
    Jonathan
    San Antonio
    05 TRD OR
    2 Hellas, 3 inch, spiders, grill guard, 285's, BHLM etc.
    I just stick the end of the rope in the hitch and pin that.
    It's the pin that matters anyway get a grade 8 one
  4. Jul 12, 2013 at 5:35 AM
    motionridr8
    motionridr8 Well-Known Member
    Drew
    WI
    2012 Tacoma 4x4 DCSB
    5100's/886's, ICON AAL, JBA UCAs, US Offroad Bumper, Badlands 9000lb Winch w/ Amstel Blue Synthetic Line, Rigid LEDs, TRD Exhaust
    Though that method typically works no problem, the issue arises when you're pulling at an angle or pulling something that is more stuck than you thought. The receiver and shackle reduce the amount of point loading and thus bending stress on that bolt during a pull that isn't exactly inline with the long axis of the truck. Just picture it like a bridge. The bolt spans the gap and supports the load just fine, but it wants to bend in the center. The block of steel in the middle eliminates the bending that wants to occur and the limiting factor becomes shear strength of the bolt. As it turns out, the shear strength of that bolt is much higher than its strength in bending.
    Bottom line is that the grade 8 bolt method will probably work for many recovery situations, but when you're stuck between a rock and a hard place or sinking into a mud hole, it makes me feel much better knowing that my $35k truck is getting pulled from a big hunk of (American) steel and not just a single bolt. If you've ever heard a bolt or something steel fail when overloaded, you'll understand my fear. Scary stuff.
  5. Jul 12, 2013 at 5:53 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Toyo AT2's, TRD rock rails, pro clip GPS mount, Husky floor liners
    I machined mine from 2" solid bar stock, weighs a ton but indestructable. Most aftermarket ones use cheap chinese shackles also. Best to get a good forged one. Capacity is much greater.
  6. Jul 12, 2013 at 9:59 AM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    Never even gave that a thought.....thanks
  7. Jul 12, 2013 at 4:38 PM
    AZM
    AZM Well-Known Member
    Mike C...
    AZ
    06 Tacoma Dlbc 4x4 Trd sport
    Hey thats the one I bought with the lock from another guy off this forum :cool: Mike C...AZ
  8. Jul 12, 2013 at 6:25 PM
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    2011 Timberland Mica TX Pro DC
    Stainless exhaust, 16" TRD wheels, 285x75x16 MTR Kevlars, Icon Stage IV, Icon Secondary shock hoop with adjustable remote reservoir bypass shocks, ATO shackle flip kit, AP U-bolt flip, AP Skids (IFS, transmission, T-case, diff cover)
    Scott,
    I bought a Viking offroad shackle hitch, its made in the US and I like that there are 2 sets of holes in the block so I can orient the d-ring horizontally OR vertically depending on the direction of pull
  9. Jul 16, 2013 at 6:32 AM
    motionridr8
    Drew
    WI
    That's another solid product. Good choice.
