WTB: SPIDERTRAX spacers for my TACOMA
Discussion in 'Buy / Sell / Trade' started by sincitytaco, Dec 14, 2009.
  1. Dec 14, 2009 at 10:28 PM
    sincitytaco
    sincitytaco [OP] Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    Like the title says. If you have a set of 4 spidertrax spacers you are looking to sell, him me up I'll buy them.
  2. Dec 15, 2009 at 9:15 AM
    sincitytaco
    Las Vegas
    Pm sent.
  3. Dec 15, 2009 at 12:56 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
  4. Dec 15, 2009 at 3:21 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    spidertrax spacers>AP spacers
  5. Dec 15, 2009 at 3:37 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    are the all pro a good spacer? price looks good
  6. Dec 15, 2009 at 3:44 PM
    sincitytaco
    Las Vegas
    honestly what can the difference be? The allpros aren't powder coated, but who cares.
  7. Dec 15, 2009 at 4:02 PM
    jhodge83
    SC
    17 XLT Sport
    the difference is i've never heard of anyone sheering studs on the spidertrax. quality is quality and u get what u pay for. how about a 3" spacer lift over a 3" CO lift? the spacer is cheaper and still provides the 3" of reauired lift, so they're the same thing right?
  8. Dec 15, 2009 at 4:27 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Do you have a link to that? I was going to pull the trigger on these when I get paid Thursday. :(
  9. Dec 15, 2009 at 4:33 PM
    jhodge83
    SC
    17 XLT Sport
    http://www.tacomaworld.com/forum/wheels-tires/59184-had-wheel-spacer-break-me-tonight.html
    there is another thread on here about a guy breaking a stud on a spidertrax spacer, but he didnt use a torque wrench to put the lugs on and more than likely overtorqued the shit out of them. he said he did it until it didnt move anymore
  10. Dec 15, 2009 at 4:34 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    I just bought a pair of Spider Trax spacers to hold me over until I can afford wheels. I did a search, and found a few threads on the All-Pro spacers being not good, and the exact same spacers are sold over at Marlin Crawler, and all over Ebay.
    I can't say if anybody elses spacers are bad, but I got the Spider Trax just in case! If yoy need any prodding towards the Spider Trax, here you go.
  11. Dec 15, 2009 at 4:45 PM
    sincitytaco
    Las Vegas
    Well as far as the spacer itself goes, aluminum is aluminum. And as far as teh studs go, grade 8 is grade 8. I don't see how one can be different from another. Chris where are you, lol?
  12. Dec 15, 2009 at 4:47 PM
    jhodge83
    SC
    17 XLT Sport
    AP UCA's and TC UCA's are not created equal.....same metal, same uniballs, not the same part
  13. Dec 15, 2009 at 4:52 PM
    sincitytaco
    Las Vegas
    IF they are the same metal, same uniballs, and same bushings as long as the jig is the same shape then yes they are the same part. But since patents do exist I am sure there is a difference of some kind in the design and one may be better.
    For that matter though I have never heard of anyone breaking an AP UCA.
    I am not trying to be confrontational I am just interested in saving some money. Nobody has been able to tell me the difference conclusively.
  14. Dec 15, 2009 at 5:05 PM
    jhodge83
    SC
    17 XLT Sport
    mjp2 did, but is iz h@rDc0r3!!!
  15. Dec 15, 2009 at 5:39 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Spider Trax or any other that uses a spacer with studs pressed into it is Flawed by design.These have a stud pressed into aluminum with a hole next to each stud. The design criteria is to keep you from having to knock out the studs in the rotor and put in a longer stud.
    A better design is to put in a longer stud,then you place the ' spacer" over the new longer studs. When you torque it up the spacer is in compression and only the studs are holding the wheel on. This is how Toyota designed it to work.
    Spider trax are adapters not spacers
    If you take out the old stud you have to remove the rotor and press or push them out ( I use a Hammer to Push them out). it's not that hard.
    Measure the old stud, buy new longer stud, buy spacer and you have a Jerry Rig that is better. It is always better not to have spacers or adapters on wheels!!!
    Link to "spacers" they also sell "adapters
    http://www.ezaccessory.com/Wheel_Spacers_s/27.htm
    I own a set of Adapters that i will use if I have rubbing on new wheels/ rims on UCA until I can get spacers and longer studs that will fix the rubbing on UCA.
    Studs set in aluminum with a hole next to it on both sides cant be good.I don't care if it is T6.
  16. Dec 15, 2009 at 5:58 PM
    kevhogaz
    SR5 PreRunner
    Somebody post up how many Spider Trax SPacers have failed if they can find it. I couldn't.
  17. Dec 15, 2009 at 8:34 PM
    jhodge83
    SC
    17 XLT Sport
    i found the one, but it was due to install error by being overtorqued...besides that i have seen none
  18. Dec 16, 2009 at 9:15 AM
    lembowski
    Rolando, CA
    Jeeper Creeper
    I wonder if that has anything to do with the fact those were lug-centric apdaters instead of hub-cenctric?
  19. Dec 16, 2009 at 9:30 AM
    kevhogaz
    SR5 PreRunner
    That's a good thing, since I've got Spider Trax spacers on my truck, right now!
  20. Dec 16, 2009 at 11:49 AM
    jhodge83
    SC
    17 XLT Sport
    yeah...as long as they're correctly torqued, u have nothing to worry about
