WTB: Stock fog light switch
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Ez2typethis, Feb 5, 2012.
  1. Feb 5, 2012 at 11:48 AM
    Ez2typethis
    Ez2typethis [OP] Well-Known Member
    Santa Maria, CA
    10 TRD sport 4x4 TRD S/C, TRD Cat back
    My 2010 4x4 TRD sport: Bilstein 5100's in the front set at 1.5" to level, TRD Supercharger, TRD Cat back, TRS retrofit, Satoshi grill, Redlinetuning hood struts, Socked ***SOLD***
    Looking for a stock fog light switch, plug and some wire off the back. Thanks!
    Switch is for new offroad lights behind grill
  2. Feb 5, 2012 at 12:56 PM
    dajabr
    dajabr Flyin' Singin' Writin' Weirdo Freak
    Dan
    Charleston, WV
    Convenience Pkg
    They are very rare here. I have been fortunate enough to snag some hot items quickly (fogs tow hook) but a fog switch WITH plug AND wires is a long shot. Granted, someone may have exactly this, if so you'll get it here in a bit and make me look bad for not asking sooner myself. :) But considering the time and effort I am going to just buy this kit and have it over with...
    http://www.trdparts4u.com/Scripts/prodView.asp?idproduct=-7001
  3. Feb 5, 2012 at 2:00 PM
    dajabr
    Dan
    Charleston, WV
    Convenience Pkg
  4. Feb 5, 2012 at 4:21 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    I have a extra switch, same as the stock fog switch. Will grab pictures this evening. No cables, $25 shipped.
  5. Feb 5, 2012 at 4:27 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    The stock switch from Toyota is 50.00 although those look clean it can be done for cheaper if you just solder in to the connections on the switch
  6. Feb 7, 2012 at 5:28 PM
    Ez2typethis
    Santa Maria, CA
    I like these, will they fit in the blank spot next to the normal fog switch seamlessly? looks like they might.
    Thanks for the links!
  7. Feb 7, 2012 at 6:39 PM
    dajabr
    Dan
    Charleston, WV
    Convenience Pkg
    The top one is for an FJ switch, cooler since is has the light to indicate the fogs are on, includes a length of wiring harness, but needs to have notches made in the switch housing to fit the Tacoma dash, and a little extra wiring to make the "on" light work. No biggie.
    The other is stock for the Taco, but you will need to run your own wiring. I have an aftermarket harness for a 04 camry that is essentially the same as stock, and when the time comes I'm just going to make it work with the FJ switch...
    But!!! Consider your time looking and waiting and checking and waiting and checking is worth something too. Either way, you just shell out $50-70 and you don't have to sit here checking every night for every little piece of this rare item required to get the stock look for who knows how long. $70 is cheap when you think of it like this. Stock radios, floor mats, etc are fast and cheap here, worth it to buy them on the forum.
    GL
  8. Jul 9, 2012 at 7:59 PM
    dajabr
    Dan
    Charleston, WV
    Convenience Pkg
    Finally did it. Was checking around less and less frequently per above, got fed up with the deal hunt on my parts and just bought them. FJ Fog switch with harness and Intermittent wiper stalk. Brand spanking OEM New. Will have them in this weekend. Should not have wasted so much time.
    Thanks to this forum though for part numbers and other info.
  9. Jul 9, 2012 at 10:29 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    how much did you pay if you dont mind me asking?
  10. Jul 9, 2012 at 10:31 PM
    Punkindrublic
    Punkindrublic Well-Known Member
    Greensboro, NC
    2007 Double-Cab TRD Off-Road
  11. Jul 10, 2012 at 5:53 AM
    dajabr
    Dan
    Charleston, WV
    Convenience Pkg
    Wiper stalk shipped, $127. FJ Fog switch with harness shipped $71.
