WTB Stock Light Switch
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Techoma, Jun 2, 2011.
  1. Jun 2, 2011 at 8:15 AM
    Techoma
    Techoma [OP] This is the Wild, Wild, West!
    Fountain Hills, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with CVT Mt Shasta Neon Green, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    My Satoshi is about complete... and Hella Slims are on the way. I'm looking for one or two OEM switches for the dash (may as well use those "blank" spots!) to wire up the Hella's.
  2. Jun 2, 2011 at 8:19 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Don't forget the oem plastic connector and 4 pigtail wires for the oem switch. That way you can wire the wiring harness to it so it'll plug into the switch all factorylike.
  3. Jun 2, 2011 at 8:25 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You don't need the harness for the OEM switch, it just makes the connection a bit easier. The OEM switch has 4 small tabs sticking out the back which are a pain to hook up without the harness but it can be done with a few choice 4-letter words.
  4. Jun 2, 2011 at 8:25 AM
    Techoma
    Fountain Hills, AZ
    Thanks..... I want it ALL... I want it now (I'm hearing some TV commercial in my head now)!
    Thanks for the heads up!
  5. Jun 2, 2011 at 8:26 AM
    Techoma
    Fountain Hills, AZ
    :DI'm retired squid... I have lot's of choice 4 letter words laying around!!!!
  6. Jun 2, 2011 at 8:31 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I just like how clean it is and easy to remove (like if you trade in your truck for another tacoma minus all the stuff you added on for reuse on the new one)
  7. Jun 2, 2011 at 9:00 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I've got this switch if you are interested. $20.00 shipped.
  8. Jun 2, 2011 at 9:28 AM
    Techoma
    Fountain Hills, AZ
    Thanks.... Just purchased a couple. Good God there's a TON of info here for the asking!!!!
