WTB: Tacoma Bike Mount attachment for bed rail
Discussion in 'Buy / Sell / Trade' started by auart, Jun 27, 2009.
  1. Jun 27, 2009 at 11:07 PM
    auart
    auart [OP] Well-Known Member
    ART
    Auburn, Alabama
    2009 Tacoma Prerunner TRD Off road 2wd
    TRD OFF ROAD, Tow Package, Scanguage2, Secure Tailgate Mod, OEM Tacoma Bed Mat, Stainless Side Step Bars, Extang Trifecta Cover.
    Anyone have one or TWO of these they want to get rid of ?
  2. Jun 28, 2009 at 8:05 PM
    owen06
    owen06 Well-Known Member
    Hinesville, GA
    16 DCSB 4x4 Red
    If you're interested, I fabbed my own using a regular front fork mount and a couple of 3/8" x 1 1/2" button head bolts and some washers. I mounted three to the front rails and it works great. Total cost, maybe $23 each, including the fork mount.
    I can post some pics tomorrow and/ or instructions on how to make it.
  3. Jun 28, 2009 at 8:09 PM
    auart
    ART
    Auburn, Alabama
    Sounds good. Need directions for sure!
  4. Jun 28, 2009 at 8:15 PM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    If you search, I do think someone posted pics of said mod..
  5. Jun 28, 2009 at 8:21 PM
    owen06
    Hinesville, GA
    16 DCSB 4x4 Red
    Ill post some pics tomorrow, but the jist of what I did:
    Used 2x 3/8" x 1 1/2" long button head bolt
    4x 7/16 fender washers
    2x 3/8" lock washers
    2x 3/8" nuts
    1x fork mount
    The bolts will be wide enough to slide into rails, but there is alot of play, so I put one washer (used a cut off wheel and trimmed washer just slightly to fit) on the bolt then slid it into the rail.
    The you take the mount with two 3/8" holes drilled into the bottoms and slide it onto the bolts with another washer between the rail and the mount on each bolt. This second washer keeps the mount from going into the rail as you tighten (mounted depending, one of my mounts was wide enough that it wasnt sucked into the rail, so i didnt need the second washers on that one).
    Then add the lock washers and the bolts and tighten. I had to use pliers to hold the bolt as I tightened the nuts because the bolt head has nothing to grab onto. (Not to insult your intellect, but the button head bolts are the bolts with the round mushroom- like heads).
    And thats it. Like i said, i will post pics (of the finished product) tomorrow if I can remember. Pics are worth a thousand words as they say.
  6. Jun 29, 2009 at 3:53 PM
    owen06
    Hinesville, GA
    16 DCSB 4x4 Red
    This is what I did, described above. Looking at other threads, people mentioned using two washers together so the one washer doesn't bend. Also I guess you can use any type of bolt, as long as the washer is big enough.
    HTH.
    - Josh
  7. Jun 30, 2009 at 11:01 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    13 Taco Double Cab TRD
    Bilstein 5100's all around, front set at 2.5", Toytec AAL, 265/75/16 Duratracs, Pro Comp 5001, Weathertech's, AVS In Channel Visors, Nokya Hyper Yellow fogs, CB Set up, Color matched grill surround, ATC Camper Shell with Yakima Racks, SOS Concepts Regular Rear Bumper.
    I got 2 from ebay for like $28...you might check there..
