WTB: Tacoma Rear axle w/Locker :WTB
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by goomba, Feb 2, 2011.
  1. Feb 2, 2011 at 10:01 AM
    goomba
    goomba [OP] It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    I am looking to buy a Tacoma rear axle with a locker in it. It needs to have 4:10 gears, and no abs. Also not in a rush to buy, I want to see how much they usually go for.
    I found one in a local junk yard for $550.
    Thanks.
  2. Feb 9, 2018 at 3:20 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    lomita
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, racerunner coilovers up front
    Go get the one you found before it's gone that's the going rate especially if drum to drum.
  3. Feb 9, 2018 at 7:30 PM
    BartMaster1234
    BartMaster1234 A Whole New Meaning to Taco Truck
    Tyler
    San Francisco Bay Area, California
    '98 Tacoma PreRunner 4WD / '98 Tacoma SR5 5-Lug
    2WD to 4WD Swap Power Door Retrofit '17 TRD OR Wheels
    I don't think it's there anymore considering it's been seven years since the OP posted this :anonymous:
    JaCado likes this.
  4. Feb 9, 2018 at 7:38 PM
    1st4x4
    sam
    lomita
    Wow that is crazy I now see the date but for some reason it showed up at the top of the list for me
    BartMaster1234 likes this.
  5. Feb 9, 2018 at 9:18 PM
    Dalandser
    Dalandser ¡Me Gustan Las Taco-mas!
    Anthony
    Downey, LB
    Empty Wallet Mod
    Go to where it lists all of the threads and look for "Last Message". The arrow should be pointing down, yours is pointing up if this thread came up first.
  6. Feb 9, 2018 at 10:03 PM
    1st4x4
    sam
    lomita
    You are right idk how that ended up happening.
  7. Feb 10, 2018 at 2:20 AM
    Dalandser
    Anthony
    Downey, LB
    Empty Wallet Mod
    It happens once in awhile.
