WTB Temp/compass console for 09 dblcab
Discussion in 'Buy / Sell / Trade' started by olggeezer, May 8, 2009.
  1. May 8, 2009 at 4:14 PM
    olggeezer
    olggeezer [OP] Member
    Ohio
    09 4x4 SR5 DBL Cab
    Fog light, DDL ,Tailgate theft mods
    Looking for that elusive item....temp/compass overhead console for double cab...any leads would be appreciated.
  2. May 8, 2009 at 4:20 PM
    dallas05taco
    dallas05taco meow.
    Dallas
    2005 Offroad Edition
    3" Toytec lift, Shrockworks sliders, Bilstein 5100s, Total Chaos UCAs, AR Mojaves, BFG A/Ts, BHLM, TRD CAI, Magnaflow Cat-Back exhaust, URD MAF sensor CAL, Doug Thorley LT Headers, URD rear O2 sims, scanguage, Wet Okole seats, Unichip.
    your's went out on you too huh? sucks.
  3. May 8, 2009 at 4:21 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    did yours die? or did your truck not come with it and you want to add it?
  4. May 8, 2009 at 5:46 PM
    olggeezer
    Ohio
    09 4x4 SR5 DBL Cab
    Just want to add one. The truck did not come with one originally....
  5. May 8, 2009 at 10:40 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    oh, good luck to ya buddy. free bump
  6. May 9, 2009 at 6:02 AM
    Sideways
    Sideways Well-Known Member
    Maryland
    05 TRD dbl cab
    Oldgeezer - From what I understand the console from an 05+ will work in an 09, except for the temp sensor that is mounted in front of the radiator.
    The 09's use a different sensor than the 05-08's
    You might want to make sure your truck is prewired for the temp sensor as well.
    If it is, the install is much easier.
    Dallas 05, if yours stopped working, do a search.
    There is a quick easy fix.
  7. May 9, 2009 at 1:39 PM
    olggeezer
    Ohio
    09 4x4 SR5 DBL Cab
    Thanks for the info. I did remove the stock console and it is wired for the temp/compass.....not sure how to check what sensor I have.
  8. May 9, 2009 at 7:45 PM
    Sideways
    Maryland
    05 TRD dbl cab
    The sensor itself will more than likely not be there, you will have to buy that separate.
    You need to check under the core support, behind the left headlight to see if the wiring and plug for the sensor is there.
    The sensor will mount to the lock support, behind the grille.
    If you get a chance, stop by a dealer and look under the hood of a Tacoma that is already equipped with the overhead console.
  9. May 9, 2009 at 9:47 PM
    tc2008
    tc2008 Well-Known Member
    Garden Grove, CA
    06 Speedway Blue
    8000K HID light, LED map and dome light, cluster + AC blue, Camburg 2.5 front and rear, Deaver 10 Packs. Satoshi Grille, Eyelids, Carbon fiber hood w/ scoop, BHLM, 285/75/16 km2s, KMC enduros
    I can sell you mine for $160 + your old overhead center console, it was just been replaced brand new by toyota 2 months ago....I'm going with a different route on my truck...
  10. May 10, 2009 at 7:33 AM
    olggeezer
    Ohio
    09 4x4 SR5 DBL Cab
    Thanks for the guidance on this Sideways. I will be off to the dealer to check the sensor. I did check my truck, and there is a black "item" just to the left... of the left headlight that looks nothing like the sensor in the middle of the grill, but seems to have nothing hooked to it?
    Just to be clear on this mod....I do need a 09 console and not a earlier one as anything before 09 will not work?
  11. May 10, 2009 at 7:37 AM
    olggeezer
    Ohio
    09 4x4 SR5 DBL Cab
    pm sent....
  12. May 14, 2009 at 9:28 AM
    kevinva
    kevinva Active Member
    Virginia
    09 Double Cab SR5 4x4 Longbed
    An 09 console will just plug into the connector that is already in your vehicle and work. An 05-08 console will not just plug right in and work -- Toyota changed the wiring for the temperature probe so that on the 09 model it goes into the A/C system, then the A/C system sends a signal to the overhead console (using a single wire). On the 05-08 models the temperature probe is wired directly to the overhead console (using two wires).
    An 05-08 console will work in an 09, but it won't plug directly in. If you use an 05-08 console in your 09 you will have to install a second temperature probe and run the two wires from it directly to the overhead console. So it can be done but it would be easier to just plug in an 09 overhead console, if you can find one.
  13. May 14, 2009 at 12:03 PM
    olggeezer
    Ohio
    09 4x4 SR5 DBL Cab
    kevina, Thanks for the info. I was just needing a little push to make the decision! Thanks
  14. May 18, 2009 at 10:52 PM
    kevinff
    kevinff Member
    Sunny AZ
    2009 Tacoma 4x4
    can you buy these somewhere online? I have an 09 4x4 access cab.
  15. May 19, 2009 at 4:25 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices.
    Is this offer still valid? If so, would be interested in purchasing, exactly what condition is it in, good shape, working properly, scatched,banged,etc.? I take it, it is from a 2008 Tacoma? Could you provide pictures?
