WTF did I do to my AR?!
Discussion in 'Guns & Hunting' started by TacoNH, Sep 10, 2017.
  1. Sep 10, 2017 at 7:58 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Looking down the barrel towards the butt stock left (counter-clockwise) would be loosening, however that barrel nut has not loosened.
  2. Sep 11, 2017 at 5:48 AM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    Why not contact your friend and the shop? If I'm not mistaken don't some of the older MI rails have a habit of twisting? My friend mentioned that when he was installing his, I think they updated the design to fix the issue.
    hillbillytoyo likes this.
  3. Sep 11, 2017 at 7:23 PM
    MidTennTaco
    MidTennTaco Active Member
    Middle Tennessee
    2017 Tacoma TRD Sport 4x4 DCSB
    Dobinsons 2” Lift Kit TRD Pro Grill TRD Pro Wheels Cooper STT Pro 265/70/17 TRD OR Skid Plate Bakflip MX4 Tonneau Cover 3M Tint to match rear 10 Coat Plastidip Badges Removed Air Dam Removed Old Man Step
    This is a common installation problem. I've done this myself. The bolts were over torqued. You need to use a torque wrench to apply the proper amount of force. On the plus side it's mostly cosmetic as those tabs are for alignment purposes only, however it looks like complete and utter garbage. I recommend any rail system that does not use this system AND using a torque wrench. :)
    MotoEd likes this.
  4. Sep 14, 2017 at 1:26 PM
    GPC
    GPC Well-Known Member
    LFOD
    2015 Tacoma TRD Pro
    Make him fix it if he values his reputation. That is one good thing about gun shops they get a bad rep they are finished.
    Lot of you tube gunsmiths that have no clue what they are doing.
    Let me guess shop that is located before the strip? I know your AO well.
  5. Oct 14, 2017 at 3:32 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    This times two. He'll have to back the barrel nut off just a little to get everything lined back up but the tabs on the forearm are toast. It'll probably function fine but for what you paid, they shouldn't be broken.
    I'd ask him to replace it.
