WTF? headlamp help?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sodbuster, Jan 23, 2011.
  1. Jan 23, 2011 at 11:08 AM
    Sodbuster
    Sodbuster [OP] Active Member
    I am trying to replace a headlamp bulb. The manual says to remove the rubber cover. I finally just pulled it out. The clip, bulb and rubber cover cam out together. I can't get the rubber cover off the bulb? Help, please.
  2. Jan 23, 2011 at 11:32 AM
    Sodbuster
    Had to ease the rubber boot off with a wooden stick. I can't figure out to orient the clip that holds the bulb in. I'm looking at the other one but can't see it well due to the windshield washer fluid tank. I've beenfiddling for hours and can't figure out how the clip goes on. This is so damn complicated Why not just twist in like my old Ford?
  3. Jan 23, 2011 at 11:36 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    The little clip kinda snaps in like a hinge...you have to un-hinge it and it swings open. Then the bulp will pull right out
