wtf how do I get the steering rack off?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by lonzorizo, May 11, 2011.
  1. May 11, 2011 at 12:24 PM
    lonzorizo
    lonzorizo [OP] Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    I'm tying to replace my rack and pinion bushings and I got all the bolts out but how the hell do I get the rack off to replace the bushings? I can only move the rack like a quarter inch or more back and forth but I been shaking the hell out of it and pulling but it just sits back to where it was. Am I missing something or whats up? All the 'how to's" i followed just said to simply remove it.
  2. May 11, 2011 at 12:58 PM
    jberry813
    jberry813 Making TW Great Again Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  3. May 11, 2011 at 12:59 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I had the same issue. I finally got it off but it wasn't easy. Keep at it!
  4. May 11, 2011 at 1:00 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  5. May 11, 2011 at 2:52 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Damn I had to call it quits temporarily...have to put the bolts back in and go get my muffler welded in. I read somewhere to have someone turn the wheel back and forth while I pull on the rack to get it off the mounts. Ill give that a shot when I get back.
  6. May 11, 2011 at 2:56 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    You have the front end jacked up right? If you don't, do that first so the wheels are hanging loose. It takes the pressure off the rack.
  7. May 11, 2011 at 3:04 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Damnit you serious? I had another thread on here asking if jacking the truck up necessary and the answer i got was "no". Thanks man I need to find some taller jack stands now and my job should be a lot easier.
  8. May 11, 2011 at 3:07 PM
    96Taco
    96Taco Well-Known Member
    Alberta
    '04 V8 4Runner
    ..stay tuned
    If all else fails you can always burn those bushings out with a blow tourch...
  9. May 11, 2011 at 3:27 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    As they say in mythbusters...."There's you're problem"
    It goes without saying, but stay safe while the truck's in the air.
    Tell me you're joking.
  10. May 11, 2011 at 3:53 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    You took it loose from the steering wheel right? if you take teh rack off you need to lock the steering wheel in one position [i did it with a bungee] and take the connection loose above the subframe, but be sure to mark it with some whiteout to get it lined back up in the same spot again and the whole rack should just fall out, it took a little moving around to get mine out but its do-able. I also had mie on a lift so that may have made it a bit easier. Good luck with it
  11. May 11, 2011 at 4:21 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    There is no reason to take out the whole rack off just to change the bushings.
  12. May 11, 2011 at 4:34 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Understood, but if he is saying that it will only move 1/4 then there is something he isnt seing that is holding him up cause with the mounts un bolted you should have pently of room to put the new bushings in.
  13. May 11, 2011 at 4:38 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yeah...the front suspension loaded. :D
  14. May 11, 2011 at 6:27 PM
    Gonzoso
    Gonzoso Well-Known Member
    Keith
    NE PA
    2000 5spd 2.7L 4x4
    Tool box, Bedliner, Not too much yet as I bought it 4/28.
    I tried that but the smell was rather offensive. I found the best way is to shoot them out. My .45 was a little to big and damaged some metal, but the 9mm wouldn't quite get it done. The .40 works rather well but you gotta be careful as it's easy to overpenetrate and hole the axle/brake disk/caliper/wheel/tire assembly, and the snappy recoil means you tend to bust your knuckles off the exhaust or frame, so I'd use gloves.
  15. May 12, 2011 at 11:10 AM
    96Taco
    Alberta
    '04 V8 4Runner
    ..stay tuned
    LOL
    Hey my blowtourch method is a last ditch effort if all else fails :p Heat helps everything right ..
  16. May 12, 2011 at 11:21 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    This could get interesting... :popcorn:
  17. May 12, 2011 at 12:13 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    While i realize you're just being a smart ass, you couldn't even get to the center bushing with a blowtorch without first moving the rack towards the rear of the truck about 3 inches. OP is not having issues removing the bushings. He's having issues getting to the bushings. ;)
    Remind me to never have you work on my truck. :p
  18. May 13, 2011 at 10:31 AM
    96Taco
    Alberta
    '04 V8 4Runner
    ..stay tuned
    haha fencing wire, duct tape and zip ties don't cut it?
