Wtf is going on with my truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DRAWN, Oct 4, 2017.
  1. Oct 4, 2017 at 4:21 PM
    #61
    DRAWN
    DRAWN [OP] Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    You are weirdly fixated on this, I love my truck, the situation angers me.
    rtzx9r likes this.
  2. Oct 4, 2017 at 4:25 PM
    #62
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    Just had Toyota check the VIN two weeks ago, no recalls, no issues.
  3. Oct 4, 2017 at 4:32 PM
    #63
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    You can e-mail it to yourself and it will appear as a jpg.
  4. Oct 4, 2017 at 4:50 PM
    #64
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If I remember correctly, the Takata bags were used until this year. The later 4Runners won't be on the recall list until the time is right. Meaning, the 2010 4Runners are just now getting them replaced and only in hotter climates. Go to Google and search 4runner airbags. Pretty sure you will be on the list and that is a serious recall. But, maybe I'm wrong!
    Krucen 01 and PvilleJohn[QUOTED] like this.
  5. Oct 4, 2017 at 4:57 PM
    #65
    PvilleJohn
    Powdersville SC
    SVT Raptor
    Ahh nice, thanks for the info! I'll check into it
  6. Oct 5, 2017 at 1:31 PM
    #66
    DRAWN
    Update, heard back from the dealership, they identified a faulty crank shaft position sensor was replaced under warranty.
  7. Oct 5, 2017 at 1:32 PM
    #67
    Toyko Joe
    Toyko Joe Here for the pictures
    2nd one was bad too?!
    Glad you got your truck back.
  8. Oct 5, 2017 at 1:32 PM
    #68
    DRAWN
    Apparently.
    tcjacado likes this.
  9. Oct 5, 2017 at 1:33 PM
    #69
    Toyko Joe
    :frusty:
  10. Oct 5, 2017 at 1:56 PM
    #70
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    I thought the first one was changed out automatically due to recall, not that it failed.
    shakerhood likes this.
  11. Oct 5, 2017 at 2:22 PM
    #71
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    That's pretty suspect. They changed the part out already under recall, and then the new redesigned CPK failed? Do you have your paperwork from the first time the sensor was replaced? Should have a part number on there.
    Toyko Joe likes this.
  12. Oct 6, 2017 at 6:17 AM
    #72
    Toyko Joe
    Exactly my point. The second one should have been good to go, but failed within a few hours of use?
  13. Oct 6, 2017 at 6:33 AM
    #73
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Not sure if it was a few hours or a few weeks /months on the original CKP changeout. I assume the CKP and diff inspection recall visit(s) were done prior to the transmission work.
  14. Oct 6, 2017 at 6:35 AM
    #74
    Toyko Joe
    Hours as in run time not as in time passed.
  15. Oct 6, 2017 at 6:45 AM
    #75
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    OP should be able to confirm if failed part was the new and improved part especially if the same dealership did both services.
    This would be the first I've heard of the "new" part failing althought not outside the realm of possibility, any brand new part has the potential to fail.
    Toyko Joe[QUOTED] likes this.
  16. Oct 6, 2017 at 8:06 AM
    #76
    Cheers007
    Cheers007 Well-Known Member
    DFW
    2017 Tacoma Limited
    It's what I said all along.
    Glad it was an easy one.
  17. Oct 6, 2017 at 9:27 AM
    #77
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I'm glad they found the issue being the CKP. I'm still unclear if they replaced the original or not... but hopefully you are back to normal and ready to roll.
  18. Oct 7, 2017 at 7:58 PM
    #78
    DRAWN
    This would be the first I've heard of the "new" part failing althought not outside the realm of possibility, any brand new part has the potential to fail.[/QUOTE]
    It was replaced when I went in for the recall.
    rtzx9r likes this.
  19. Oct 7, 2017 at 8:10 PM
    #79
    tcjacado
    tcjacado Well-Known Member
    It was replaced when I went in for the recall.[/QUOTE]
    Guaranteed they just took a cpk off the shelf not caring if it was the old part or new improved cpk. They aren't going to just throw inventory away. Lol. They will use off and hope for the best, yours didn't work out for them.
    Glad it is fixed op. Gl with future repairs
    shakerhood and Lawfarin like this.
  20. Nov 21, 2017 at 5:24 PM
    #80
    DRAWN
    NOOOOOOOO. So it happened again today. While in NM visiting family my truck started having problems again. The surging during acceleration is back along with loss of power. Twice the truck has just died on me, both times high trans temp warning and low oil pressure warnings popped up. Possible CPS Failure? Transmissions problems? I called the local dealership unfortunately they close at 5. Will try to get the dealer to check it again tomorrow. :frusty::frusty::frusty::frusty::frusty:
