WTF is this creaking noise??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Northern Taco, Jun 27, 2017.
  1. Jun 27, 2017 at 7:11 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    That gives you about 5 hours of sleep after you check. No problem. :bored:
  2. Jun 28, 2017 at 5:15 PM
    Northern Taco
    Northern Taco [OP] Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Upper control arm bolts are tight. Sway bar mount bolts are tight, upper shock mounts are tight, lower shock bolts are tight. It was creaking a bit less today, but definitely still there. Sounds almost like a thin metal on metal binding sound. Work got in the way of taking it to my mechanic and putting it on the hoist. Everything I tightened is also new (and already tight) so this one has me puzzled.
    The only thing I can think of is I put new ome skid plates on and the rear one under laps the front skid. But they are tight and shouldn't flex but maybe they are flexing off road and creaking. It's my last resort.
    I just tried to take out the lower strut bolts to smear antiseize on them and they won't budge. Need to get the truck on a lift so I can get more leverage with my 2' breaker bar. My 1/2" impact gun won't touch them!
  3. Jun 29, 2017 at 4:09 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    The ole forward backward method worked for my strut bolts. One ooga forward, one ooga backwards, and repeat till out!
    Slvr14tacoma likes this.
  4. Jun 29, 2017 at 6:27 PM
    Northern Taco
    I'll give it another try when I get some time. Doing a few yard projects before the big 150th b day celebrations up here. My mechanic I usually go to is gone until august.
  5. Jul 2, 2017 at 10:01 AM
    Northern Taco
    I just got finished taking the lower shock bolts out (61 ft lbs my ass) and smeared anti seize all over them. Still have the creaking/clicking sound but seems to be a lot better. Also noticed my new skid plate was bent on the front drivers corner up against the frame cross member (where tow hook mounts). So I bent it back straight. I'll know better next time I take it for a drive how it sounds.
  6. Jul 2, 2017 at 4:13 PM
    Chhhhn
    Chhhhn Well-Known Member
    07 DCLB Sport
    Have you checked your wheel bearing?
  7. Jul 2, 2017 at 5:56 PM
    Northern Taco
    Just got back from a drive and it's no longer creaking. It was either the lower shock bolts (only 3 months old) or that bent piece on my skid plate binding against the crossmember. It'll make a faint creek if I flex it hard, but very minor.
    I'm just glad it's quiet now.
  8. Jul 2, 2017 at 5:59 PM
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    These newer trucks make so much more noise than my first gen. Almost considering a muffler and some ignorance
    12TRDTacoma likes this.
  9. Jul 2, 2017 at 6:27 PM
    Northern Taco
    My 1st Gen was a more solid truck (well except the rotten frame) once I ditched the sway bar that truck road so smooth.
    Slvr14tacoma[QUOTED] likes this.
  10. Jul 2, 2017 at 6:42 PM
    Slvr14tacoma
    Mid travel
    Definitely felt more solid but im just bitching
  11. Jul 12, 2017 at 6:05 PM
    Northern Taco
    Just an update, my creaking is the same as it's always been. I took off my skids plates and no difference. Loosened my rad support mounts and re torqued to spec (33 fl lbs or whatever I read on here) no difference.
    Not really sure what is making this sounds. I can't see my lca bolts seizing in 3-4 months and they were brand new.
    The only thing not replaced were my uca's but they seem tight, and the bolts are definitely tight.
    I know I'm tired of crawling under the truck and messing around with things that don't fix the problem, usually in the dark after work.
    I'll take it to my mechanic when he's back in august I guess and see what he thinks.
  12. Jul 12, 2017 at 6:15 PM
    Justinlhc
    I wish I could be there to track it down for you. I'm like a drug dog in a crack house when it comes to foreign noises on my truck. If it's not supposed to be making a noise, my nose hairs twitch. o_O
    R0dzilla75 and 12TRDTacoma like this.
  13. Jul 12, 2017 at 6:16 PM
    Northern Taco
    It's a 2 person job, sometime I'll get someone in the drivers seat I trust and stab the brakes going in forward and reverse to replicate the creaking sound (metal sound) while I'm under the front of it.
    Justinlhc likes this.
  14. Jul 12, 2017 at 6:19 PM
    Justinlhc
    I've had my wife driving circles in empty parking lots more than once :anonymous:
    Blockhead likes this.
  15. Jul 12, 2017 at 6:36 PM
    #35
    Northern Taco
    I tried her driving but I just kneeled in front of it. She's a few weeks from having our 2nd son so you know hormones and such might make her want to run over a part of me. :rofl:
    TacoTronics and xJuice like this.
  16. Jul 12, 2017 at 11:11 PM
    #36
    natas1321
    natas1321 mischief monkey
    natas
    san antonio
    1990 Honda NC30 stock for now
    you might check out the intermediate steering shaft u-joints they were making a creaking noise on my first gen that had me guessing for a week and was driving me crazy.
  17. Jul 13, 2017 at 12:37 AM
    #37
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My money is on the sway bar.
  18. Jul 13, 2017 at 1:05 AM
    #38
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I had my wife drive my truck back and forth in the garage dragging me along with it as I held onto my skids plates trying to hunt down noises :rofl:
    bax likes this.
  19. Jul 13, 2017 at 1:15 AM
    #39
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
  20. Jul 13, 2017 at 2:02 AM
    #40
    natas1321
    natas
    san antonio
    I believe he already replaced the bushings and links. I did the same on mine while hunting down what was causing the squeaking on my truck.
    12TRDTacoma[QUOTED] likes this.
