WTF is this new noise my 3.4L is making.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02 quadcab, Jan 8, 2017.
  1. Jan 15, 2017 at 11:15 PM
    #41
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Those Nachi bearings are great too if it is genuine. The Chinese have taken to ripping off the weirdest things lately, one of them being bearings.... the other being NipponChemicon capacitors. I've run into some duds so I try to buy items like this from approved retailers.
  2. Jan 16, 2017 at 7:44 AM
    #42
    02 quadcab
    02 quadcab [OP] Well-Known Member
    whoops i threw the old assembly away already. yeah i just figured it was such an easy fix that i wasnt too worried about doing it again in a few years if needed. plenty of other problems ill prob encounter by then.
  3. Nov 11, 2017 at 7:54 AM
    #43
    WVTaco12
    WVTaco12 Well-Known Member
    Cody
    West Virginia
    2013 TX Baja
    My ‘02 is making the same exact noise. I was going to just buy the new idler pulley from Toyota, but when I called them this morning, they were having trouble giving me an exact part. He was asking if I was looking for the timing belt idler pulley, the a/c idler pulley, or something else. Can you all tell me which one, specifically, that it is? Maybe even a Toyota part number?
    Thanks.
  4. Nov 11, 2017 at 8:59 AM
    #44
    tony2018
    tony2018 Well-Known Member
    Yes, there are couple. a/c pulley that is adjustable to tension belt. Timing belt has 2, 1 between the cams and 1 on the auto tension.
  5. Nov 11, 2017 at 1:12 PM
    #45
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    If it's the AC idler pulley making noise, just cut the belt off and run it without it all winter and replace in the summer. I have had to do this a few times. I had that pull seize up and break the belt on the interstate, somehow it didn't break anything else, I got lucky on that one.
    Road salt and sandy mud tears those pullys up around here.
  6. Nov 13, 2017 at 6:29 PM
    #46
    WVTaco12
    Cody
    West Virginia
    2013 TX Baja
    Got my ac idler pulley ordered. Anyone have some pics or a video on how to replace it?
  7. Nov 14, 2017 at 12:21 PM
    #47
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I don't know why you need a video - it's a simple job.
    1. Remove the front rock shield. This part takes the longest.
    2. Loosen the belt that goes around the pulley.
    3 .Remove the bolt from the center pulley and remove the pulley.
    4. Assuming you just want to replace the pulley, just mount it where the old one went.
    5. Reinstall and tighten the bolt. I don't know the torque spec, I just tighten it tight with an 8-inch wrench.
    6. Reinstall the belt and adjust its tension. If you wanna be anal about it, get yourself one of those belt tension tools to measure the belt's tension. In my 55+ years I've never bothered with it and I've never had a loose belt or a prematurely bad bearing.
    7. Reinstall the front rock shield.
