WTF is this thing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by powder1134, Jun 10, 2020.
  1. Jun 10, 2020 at 7:50 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
  2. Jun 10, 2020 at 8:17 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    My 2015 had the same thing installed by the selling dealer when I bought it as a 2y old truck. KARR sells them to dealers so they can have one-remote opening for everything on the lot, and then they try to get the buyer to pay (overpay, actually) for a security system to subsidize their one-remote convenience program.
    Yours has the "deactivate" module installed -- that little dimpled rectangular piece in the front of the switch. The switch and the alarm are doing nothing now.
    I took mine out completely last year -- spliced the original ignition wire cut for the alarm's orange main switch and disconnected all the other wire taps.
    NmapFE, jackn7, ZColorado and 5 others like this.
  3. Jun 10, 2020 at 8:26 PM
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    Pacemaker for the Taco. Or a Fidget-Button. Maybe activates Cheat-codes like flying mode or infinite lives...
    jackn7 and Mully like this.
  4. Jun 10, 2020 at 8:32 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    “Gigawatts”
    :annoyed::facepalm:
    jackn7 likes this.
  5. Jun 10, 2020 at 8:33 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Rectal BAC tester.
    Don't ask how I know.
    jackn7, JimIowa and tcjacado like this.
  6. Jun 10, 2020 at 8:48 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pull that crap out of there and repair the column harness back to stock
    :sawzall::welder:
    jackn7 and tcjacado like this.
  7. Jun 11, 2020 at 9:09 AM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    "My sensors are picking up danger Michael." Knightrider Circa 1982
  8. Jun 11, 2020 at 9:18 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    This.
    Its the program button and glass break sensor
  9. Jun 11, 2020 at 9:23 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Maybe it’s a 3rd gen transmission shift improver and was mistakenly installed on a 2nd gen with a good motor and trans package?
    Taco 422 and jackn7 like this.
  10. Jun 11, 2020 at 10:55 AM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Aftermarket alarm many dealers have installed to jack the price up when they sell the vehicle.
  11. Jun 11, 2020 at 6:15 PM
    mx07gt
    mx07gt Well-Known Member
    5G forcefield activator.
    jackn7 likes this.
  12. Jun 11, 2020 at 10:14 PM
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    Thanks for that, I’ve been wanting to remove mine but I was worried it would deactivate the truck somehow.
  13. Jun 12, 2020 at 4:26 AM
    4xdog
    Santa Fe, NM
    I’ve removed two aftermarket alarms over the last couple of years (one from my Gen 1 and this from my Gen 2) so I have a little experience and more confidence in doing it.
    When you first remove the KARR alarm the truck will indeed not run. An ignition switch wire was cut by the installer and the two ends were connected to the alarm's main circuit. (These wires were orange on my KARR alarm.) That’s how the alarm works to immobilize the truck -- the alarm box functions as a second "switch" in the ignition circuit. The alarm's main ignition wires are heavier gauge than the light gauge used for all the other alarm harness wires, like to door locks, etc. You can see those orange wires at the top of my photo of the laid-out alarm, connected to that black cube relay.
    The truck ignition circuit cut to install the main alarm wires needs to be spliced back together. Then the truck will run again. All the other alarm wires are taps into other truck circuits or ground wires attached to the body and can be easily and simply disconnected.
    I have a bunch of photos from doing mine if that would help. On my 2015 DC TRD OR the circuit cut to install the KARR alarm was the green with black tracer wire shown in this image. Doing a good splice on this is the hardest part of removing the alarm.
    (No liability accepted for folks who dig into their ignition wiring and do it wrong. My experience offered as information for those interested. :))
  14. Jun 12, 2020 at 7:53 AM
    tamer
    tamer hamerworx.com
    NorCal
    Awesome, thanks man. So I’ll assume mine is probably gen/blk as well. I’ll take a look back there this weekend and see what I’m getting into. Seems straightforward enough. Appreciate the help!
  15. Jun 12, 2020 at 10:11 AM
    #35
    4xdog
    Santa Fe, NM
    The KARR alarm module will likely be stuffed up above the parking brake pedal someplace. You can see it here on my truck ziptied to the car harness.
    There will be a bunch of spade-connector T-taps on miscellaneous wiring. You can see a few of 'em here. Note also in this photo the orange wire from the alarm crimp-spliced into the car's ignition harness. This is the key part that immobilizes the car. To remove the alarm those orange wires (on a KARR system) need to be taken off and the original wire re-joined.
    TRDSport10 and tamer[QUOTED] like this.
  16. Jun 12, 2020 at 10:15 AM
    #36
    tamer
    tamer hamerworx.com
    NorCal
    Did you leave the taps on the original wires? Or just pulled the plugs off?
  17. Jun 12, 2020 at 10:31 AM
    #37
    nd4spdbh
    SoCal
    If i was to remove the Karr system from my truck id end up removing the T Taps and wrap the wire where the tap was with a piece of electrical tape
  18. Jun 12, 2020 at 10:32 AM
    #38
    4xdog
    Santa Fe, NM
    I've removed the taps on my Gen 1 (which had a different alarm). That was a pain. Trying to de-pin the original harness and slip a short piece of shrink tube over the break in the original insulation was difficult. And simply wrapping the original insulation with PVC tape is probably no better than leaving the original T-tap in place.
    On my Gen 2 in the pix above, I simply left the T-taps in place. Little risk something is going to get inside the connector given its location.
    I'd recommend not fooling with the abandoned taps.
  19. Jun 12, 2020 at 10:33 AM
    #39
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Ejector seat drops nails, sprays gas, shoots missiles. James Bond shit.
    Casper66 and powder1134[OP] like this.
  20. Jun 12, 2020 at 10:36 AM
    #40
    Jose_Dirte
    Jose_Dirte Life's a garden, dig it
    Joey
    Green Acres, CO
    A Tacoma, just like everybody else...
    Wrong, it's definitely"gigabobs"
