WTF truck stays on after key is turned off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kinkymike, Oct 17, 2011.
  1. Oct 17, 2011 at 7:29 PM
    kinkymike
    kinkymike [OP] Member
    Tijuana Mexico
    05 prerunner sr5 TRD
    hey guys
    has any body run across this problem?
    something that i did not add on the video is that as soon as i plug the negative terminal to the battery my brake lights stay on as if someone was pressing the brake pedal, already checked the pedal switch and its fine, also i have an after marked viper alarm i unplugged it and same problem
    please help!!!!!
    thanks
    http://www.youtube.com/watch?v=dyHWo39RNxc
  2. Oct 17, 2011 at 7:31 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    video?
    Zombie truck. Kill it with fire.
    bump for you cause I suck with electronic stuff
  3. Oct 17, 2011 at 7:33 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    :confused: :confused: :confused:
    whattt the fuck?
  4. Oct 17, 2011 at 7:34 PM
    CelticTaco151
    CelticTaco151 Well-Known Member
    Kate
    Cincinnati
    2011 TRD Off-Road DBL Cab 4x4
    that is scary! extended warranty w/electronic coverage?!
  5. Oct 17, 2011 at 7:34 PM
    woods247
    woods247 Well-Known Member
    back yonder
    09 TRD Sport Double Cab 4x4
    SAWs front, Fox resi rear, Total Chaos UCAs, 17" BBS RD-Truck FJ Rims with 255 BFG KM2s, TRD exhaust/intake, OME Springs, All-Pro flip kit, Timbren rear bumpstops, custom spare carrier, All-Pro skids, Beefed Sliders, All-Pro front bumper, Warn M8000 w/Synth MasterPull line, Procomp 30" LED lightbar, Bestop Soft topper, Safari Snorkel, CBI Bushmaster (custom), Baja Racks Utility rack, All Pro custom bed rack, Leer 100XQ
    That's f'd up. :confused: I'd say a trip to the dealer is in order.
  6. Oct 17, 2011 at 7:36 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Optical Illusion. He's using his spare key to trick you, haha
  7. Oct 17, 2011 at 7:36 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    That is super weird. Have you tried disconnecting your battery and reconnecting it after ~ 30 minutes? The brake thing is the weirdest part, doesn't make any sense. I would take it to the dealer.
  8. Oct 17, 2011 at 7:36 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Well for one that's weird
    For two, sounds like the guys who did the alarm fobbed something up
    and for three, that's just weird.
    I understood if you had something like your cylinder on your ignition was broke and you can pull the keys out while it's running..common problem but if it's still running with key out of ignition and it's actually running(not dieseling)..then that's interesting.
  9. Oct 17, 2011 at 7:37 PM
    hpsnowburn
    hpsnowburn Member
    Henry
    Issaquah, WA
    09 Access Cab 4x4 TRD Offroad
    Do you have remote start? It has to be the Viper system. If you have a remote start kit properly installed and you turn the truck on using the remote, if you touch the breaks it will turn off if the key is not in it. The Viper system is either improperly installed or they installed the wrong kit which may contain a remote start feature that you didnt want. The truck is assuming you started it remotely and that is why when you hit the breaks it turns off with the key out.
  10. Oct 17, 2011 at 7:37 PM
    TruthInLies313
    TruthInLies313 Well-Known Member
    Blaine
    Texas
    05 V6 TRD Sport DC
    Tinted, 5701 Viper Alarm Electric Start, 6 Inch Fabtech Lift, 17'' XD Hoss Rims, K&N 77 Series Intake, BHLM, Black Emblems, Color Matched Dash rings, 2 JL 10's, Pioneer Double Din Head Unit
    x2
  11. Oct 17, 2011 at 7:38 PM
    Bloodhound
    Bloodhound Space For Rent
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Just guessing here but it looks like a wire connected to the lock/cylinder/barrel is shorted. Reason for that guess is that my remote start killed everything when the brake was pressed without a key in the cylinder and turned to "On". (<-Previous vehicle) I'd start by checking around that area.
    edit: after reading the above mention Viper Alarm problems is there a way to take it out of the equation and see if it's a bad wire or something internal to the alarm/remote start? Just something to isolate..
  12. Oct 17, 2011 at 7:38 PM
    tacoman_KC
    tacoman_KC Hurray for Zoidberg!
    John Zoidberg
    Arizona
    Subaru Outback
    Your truck sounds like it has a mind of its own. Reminds me of my parents old Nissan, it would lock its doors and roll down the windows by its self, even if the engine was off. Electrical issues can be quite annoying to repair. Good luck with the fix.
  13. Oct 17, 2011 at 7:40 PM
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    Another thing, does it do this if you open the door?
    i know mine (unless i am remembering wrong, i havent had my truck for a few weeks :( ) woul shut off when a door was opened, and stay on if i didnt touch anything
    doubt it helps, but i figured i might throw it out there
  14. Oct 17, 2011 at 7:40 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    ^^^this...like everyone else has asked or said....if you have an alarm with remote start thats the only explanation that i can think off right off the top of my head [​IMG]
  15. Oct 17, 2011 at 7:41 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    my mom has non factory remote start on her camry. Somthing with the brake kills the remote start if you don't put the key in first.
    Sounds like that but in reverse.
  16. Oct 17, 2011 at 7:48 PM
    Bloodhound
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Kinda what I was thinking, internal short in the ignition cylinder or internal to the alarm/remote start bypassing the key.
  17. Oct 17, 2011 at 7:53 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Air Bag light usually means the coil spring has gone bad (with out the air bags ever being deployed).
  18. Oct 17, 2011 at 7:54 PM
    S.B.
    Sean
    The dealer gives me shit for my alarm that was installed by the original dealer. lol
  19. Oct 17, 2011 at 8:15 PM
    kinkymike
    Tijuana Mexico
    ok, sorry for the late reply i was checking on some stuff, the alarm does not have a remote start, that i know of, the truck had the alarm when i bought it, in the year that i have had this truck this has been the first and only problem it has given me.
    anything else besides alarm???
    what im gonna do tomorrow is remove the alarm all together, and see what hapends there, also just for kicks i removed the ignition switch (figured a push button start system may solve the problem) and the problem persisted
    im kinda at the end of my rope... :(
  20. Oct 20, 2011 at 6:41 PM
    CelticTaco151
    Kate
    Cincinnati
    chill.
