WTF was that noise/shudder?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsnm23, Feb 18, 2016.
  1. Feb 18, 2016 at 10:05 PM
    jsnm23
    jsnm23 [OP] There are no solutions; only tradeoffs.
    2011 mgm TRD OR 4x4
    5100s @1.65 MB 352 wheels Debadged Cb radio Bhlm
    K. Thanks for the help.
    Anyone ever replaced that before? Do need to take the shaft out?
  2. Feb 18, 2016 at 10:25 PM
    Syncros
    Syncros Well-Known Member
    It's not a simple task, shaft needs to come out and be dismantled. I used my bearing splitter and press to remove the carrier bearing, replaced all three u-joints at the same time. Aftermarket SKF Part was $120 and failed immediately.. did it all over again and it was still good when I sold the truck.
  3. Feb 18, 2016 at 10:29 PM
    jsnm23
    2011 mgm TRD OR 4x4
    So do you recommend oem parts?
  4. Feb 19, 2016 at 6:45 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I replaced the u-joints with Moog. Feels good.
  5. Feb 19, 2016 at 7:57 AM
    jsnm23
    2011 mgm TRD OR 4x4
    Any ideas why this bearing failed prematurely?
  6. Feb 19, 2016 at 8:02 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    IMO no. Use and wear. Now you know to check the replacements carefully in another 5 years. Have you ever changed the rear diff oil? If not, you're in for a rude awakening....yuck.
  7. Feb 19, 2016 at 9:12 AM
    jsnm23
    2011 mgm TRD OR 4x4
    Yeah, did the diffs and t case at 40,000
