WTF. Why do the V-6 engines have only one exhaust port per side
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Boss hoss, Sep 15, 2019.
  1. Sep 16, 2019 at 10:39 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I think just the opposite. Can get a turbo that much closer to the head.
  2. Sep 16, 2019 at 10:43 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i wouldnt go turbo route. i would go belt driven supercharger. With stock rods, low PSI and the demand for low rpm tq why would you want to deal with turbos or a turbo and all the exhaust piping crossing under the engine?
  3. Sep 16, 2019 at 10:45 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Honda has been doing this with the J series engines since like 2002, works really well in applications where high performance isn't necessary
  4. Sep 16, 2019 at 10:49 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    #whenkeepingitrealgoesright
    e6400ultra[QUOTED] likes this.
  5. Sep 16, 2019 at 11:23 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    No it doesn't. It means when it happens, you have a cracked head.
    stun gun and auskip07 like this.
  6. Sep 16, 2019 at 11:25 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Is that a gramaha
    SnowB, Junkhead and GreyBaldTaco like this.
  7. Sep 16, 2019 at 11:26 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Ah, another engineering marvel Toyota would do best not to copy. The J series. Should come from the factory with a VCMuzzler
    or just never been designed with variable cylinder activation to begin with.
  8. Sep 16, 2019 at 11:29 AM
    auskip07
    Skip
    Atlanta, Ga
    lol the vehicle i traded had a J35z2. i sold my vcm disabler before i sold it. Honestly solid engines... cant say the same for the transmission.
  9. Sep 16, 2019 at 11:30 AM
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    haha, gramaha, nice! Yes indeed it is a "Yamaha"....:)
  10. Sep 16, 2019 at 11:45 AM
    Speedytech7
    I think only the Accord and Odyssey had the deactivation and it was rather annoying. But the J series is actually a pretty solid performer albeit that it is solidly under it's potential likely for longevity and possibly because its an SOHC design
    auskip07 likes this.
  11. Sep 16, 2019 at 11:50 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Everything. Even Ridgeline now.
  12. Sep 16, 2019 at 11:53 AM
    Speedytech7
    Can't be worse than the V8-6-4 Caddy engine haha. I never minded the cyl deactivation much, but I wasn't exactly looking for performance from a minivan either. Honda ECUs are easy enough to gain access to that I'd imagine it's possible to disable if it was detrimental to how you use it.
  13. Sep 16, 2019 at 11:55 AM
    Timmcc02
    Timmcc02 Well-Known Member
    Tim
    2017 TRD OR
    You ever seen a cracked cylinder head on a car? About a million times more likely to burn an exhaust valve
  14. Sep 16, 2019 at 11:55 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Do it and make some money. There's a reason Muzzlers are being cloned everywhere.
    Electric motor mounts because it shakes so bad, sheesh.
  15. Sep 16, 2019 at 11:56 AM
    #35
    Speedytech7
    Yes, on two of my Toyotas no less. Its common enough. Haven't burnt a valve in a long time, was a more common event back when fueling was done exclusively with the Bernoulli effect
  16. Sep 16, 2019 at 11:56 AM
    #36
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Do a search. Actually just the opposite is true.
    stun gun likes this.
  17. Sep 16, 2019 at 11:59 AM
    #37
    Speedytech7
    I had those on a Maxima once upon a time, was the oddest thing to have the mounts stiffen up under hard acceleration, but it was pretty cool, was like a racecar in response when I wanted it and comfy when I wasn't driving like an asshole. But that's pretty bad if they're using it to cover imbalance. I don't really use Hondas how they were intended, all of my knowledge on them is from engine swaps into other things.
  18. Sep 16, 2019 at 11:59 AM
    #38
    Timmcc02
    Tim
    2017 TRD OR
    From an overheat? I don’t understand how you could have that issue before other things breaking first
  19. Sep 16, 2019 at 12:07 PM
    #39
    Speedytech7
    Nope, never overheated a Toyota, killed a Nissan like that though... Temp gauge was broken and I had no clue. Toyotas historically have pretty thin castings around the valves and spark plugs. One of mine cracked to the coolant passage after an exhaust valve tightened excessively, I had it adjusted per the FSM but the guy who did it must've missed that one. So I do my own valve adjustments now haha, and the other was just a freak thing and it actually cracked above combustion chamber and mixed oil and coolant. Cracked heads are so damn common that my head rebuilder says many of the heads he checks for people doing a head gasket job end up being cracked and the gasket was likely never the issue. Castings are cheap and done quickly, there's bound to be failures here and there, but head gasket technology, especially the MLS gaskets Toyota uses have a low failure rate unless grosely overheated.
  20. Sep 16, 2019 at 12:27 PM
    #40
    Timmcc02
    Tim
    2017 TRD OR
    In my time working on cars I’ve never seen a cracked cylinder head. Most of that has been with bmw engines though.
