WTH is this whining noise w/ my 2000 Tacoma 6 cyl?
Discussion in '1st Gen. Tacomas (1995-2004)' started by totoyotata, Dec 2, 2023.
  1. Dec 2, 2023 at 5:08 AM
    totoyotata
    totoyotata [OP] Member
    2000 Tacoma SR5 Prerunner V6 2WD auto off-road pkg +cab
    I just dashed to the convenience store this morning — 7:30 am, lots of moisture in the air — left it idling while I was briefly in the store. Came out; and it was making this noise:
    https://youtube.com/shorts/KsByCukuQ3o?si=LmBT5-kqa-joe5LI
    My iPhone has a helluva’ microphone on it. It’s not QUITE as loud as my video here — but it’s a new development, just this morning. :-|
    Yesterday, I had an odd thing happen as well when I first cranked it up. It was missing pretty badly, runnin’ rough — but it cleared up before I could swing by my mechanic (just 4.5 miles away). Same weather conditions. He ran a diagnostic on it … and nothin’, aside from a slight gallop in the idle. I’m now scheduled for a tuneup 10 days from now. Definitely gonna’ our new plugs on it. But I know this noise is not plug nor idle related.
    Please don’t tell me my water pump is going out. :’-(
  2. Dec 2, 2023 at 7:14 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I won't tell you your water pump is going out. I would check the 3 belts to be sure they are not loose though. You could also remove one belt at a time and see if the noise goes away, but that's kind of a hassle.
    totoyotata[OP] likes this.
  3. Dec 2, 2023 at 7:39 AM
    1997tacomav6
    Denver
    Lots of possibilities,
    Get a engine s Stethoscope to narrow it down, too many possibilities,
    Water pump,
    Power steering pump,
    Alternator ,
    Fan bracket pulley,
    Ac idler pulley,
    Ac unit,
    Timing pulleys
    Etc
  4. Dec 2, 2023 at 7:42 AM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    That sounds very much like another low-hanging A/C idle pulley bearing starting to sing. With all the deep mud/high water I routinely wheel thru, I kill that bearing on a very regular basis. It literally gets changed every time the skid plate is removed to change the engine oil.
    1997tacomav6 and totoyotata[OP] like this.
  5. Dec 3, 2023 at 4:04 AM
    1997tacomav6
    Denver
    That’s actually good to know as I end up replacing mine at least once or twice a year and I thought maybe the quality of the bearings had gone south.
    I was thinking of a way to make a shield or cover for that bearing.
    I’m sure the winter Sodium Chloride salt is eating up my AC idler bearings
    totoyotata[OP] and leid[QUOTED] like this.
