WTH? One of my horns doesn't work anyone!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by w8n4mud, Mar 7, 2009.
  1. Mar 7, 2009 at 7:31 PM
    w8n4mud
    w8n4mud [OP] I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    One day last week, I used my horn at work when driving around a blind corner. To my surprise, it sounded different. So I pulled over and put my hand to the horn and well you guessed it. I could hear one of the horns kicking in and out. So finally it died! I looked at the connectors and checked the fuse. No luck.
    I also checked to see if there were other threads about horns going bad. I only saw other owners upgrading to an air horn and simply replacing the factory with aftermarket. But has anyone had a similar issue? Does anyone have an extra horn laying around (assuming that's my problem)?
    Let me know. I love to use my horn. I feel stupid when I hear the damn thing. I never knew what a difference one horn could make. Anyways that's my story and I'm sticking to it!
  2. Mar 2, 2014 at 5:51 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Mine has been doing this intermittently lately. When I hit the panic button is seems work fine, but sometimes when I honk the horn via the steering wheel is sounds like a damn Hyundai or something. Then sometimes it works again. Not sure what's going on.
  3. Mar 2, 2014 at 5:59 PM
    cnw126
    cnw126 Member
    Delaware
    2013, 4X4, 2.7, 5spd, access cab, Pyrite Mica
    Not Toyota related but the horn on my 1997 Mazda b2300 died about 8 years into ownership. If I remember correctly I got a replacement at Pep Boys for $15. I am not sure of the exact problem with the old horn but the new one solved the problem and worked until the truck got totaled in 2012.
  4. Mar 2, 2014 at 6:28 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    Well hell, one of my horns has been sounding funny and sporadically working and I thought it was something related to the fender-bender I was involved in in Nov. Maybe not. :confused:
  5. Mar 2, 2014 at 7:35 PM
    wannabetrd
    wannabetrd Well-Known Member
    Zach
    Michigan
    SR5
    3inch front 2inch rear lift with add a leaf and extended brake lines trd exhaust
    Your horn is grounded thru the mount pull your horn off clean and rust corrosion and or paint off where it mounts to the body and see if that helps you know of course as long as you have power
  6. Mar 2, 2014 at 10:31 PM
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    Do all 2nd gens have two horns? My single cab has always sounded like a bike horn.
  7. Mar 3, 2014 at 2:21 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    There are two horns on the second generation. (One "beep-beep" horn on the first gen.) The gen two have a high note and a low note. Two high or two low notes wont sound right. It's the combination of high and low that makes the correct noise. Make sure that you get the right one. A Pep Boys horn will work, fine.
  8. Mar 3, 2014 at 2:25 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    Mine does it on and off i've checked the contacts a few times, cleaned them they will be fine for awhile then one will go out of a few days.
  9. Mar 3, 2014 at 2:31 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    I only have one horn on my 13'. If you want to call it a horn. More like a pathetic noise. I had 2 horns on my 03'.
  10. Mar 3, 2014 at 2:33 AM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    Oh, I see. There are a few changes year to year. You can run a two note high/low set off of your single horns wires. You'll have to crimp on some terminals. The horns on my 2009 will blow your hat off. Stock. I know that if they ever get water in them, it's soon all over. It's just a coil of wire in there and they need to stay dry and clean.
  11. Mar 3, 2014 at 2:46 AM
    car78412
    Hudson Valley NY
    I had been looking at replacing the single horn on my 13' but there is only one connection whereas the duel horn has 2. Without any complicated wiring alterations, how can I adapt the duel horns with the single connection?
  12. Mar 3, 2014 at 5:11 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Like This:
    Wire from Horn Relay
    X_____________________|X Horn # 1
    |_____________________|X Horn # 2
    Splice for horn # 2
  13. Mar 3, 2014 at 6:06 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Test the voltage at the horn and make sure it's correct. If found to be correct, then buy a new horn from a Toyota parts web site or from your dealer. They don't cost that much.
  14. Mar 3, 2014 at 8:40 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    That's the thing... it works fine when I hit the panic button but it doesn't always work fine when I hit the steering wheel.
  15. Mar 3, 2014 at 8:49 PM
    moondeath
    Pa, Gardners
    Sorry, my comment wasn't directed at you. Didn't notice the thread was old. Maybe one of your horns is just starting to go bad and intermittently doesn't work. I've had that happen on other vehicles.
  16. Mar 3, 2014 at 9:06 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yeah haha I searched and this was the closest thing that came up
