WTH, Recycled air turns to fresh by itself?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotacrawler, Oct 4, 2010.
  1. Oct 4, 2010 at 6:17 AM
    Toyotacrawler
    Toyotacrawler [OP] She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    I have a 2010 DC V6 Prerunner with 3500 miles on it and noticed something strange this morning on my way to work. The recycled air button turned off by itself and switched to fresh air. I pressed the button again and about 3 or 4 minutes later, it switched to fresh air by itself. This happened everytime I pressed the button. Has anybody else out there had this issue? My vent knob is set to front. It is not set on the windshield or floor or dual. Is there something wrong that I need to get checked out?
  2. Oct 4, 2010 at 6:21 AM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    This is normal. If you hold down the button for 4 or 5 seconds it will stay set to recycled air.
  3. Oct 4, 2010 at 6:23 AM
    Paul's TRD
    Paul's TRD I'm Not Your F***ing Brother
    TX
    2011 Z71 4x4 5.3L V8
    Mine will set to fresh, when I'm running the heat. That's they only time I have noticed it turn by itself, which is kind of annoying, b/c I usually don't notice it until I find myself breathing some nasty exhaust from a stupid bus or something and by that time it's already too late. Would like to know if there is a away from stopping this.
  4. Oct 4, 2010 at 6:37 AM
    Toyotacrawler
    Cusseta/Opelika AL
    Ok, Thanks! Does the factory set the control to do that when the air temp gets to a certain temperature? It is cool this morning. About 45 degrees. First time the temp has been that low.
    Yea, it sucks when the smell of a beater car burning oil comes straight through the vent!!!! I can't stand that! Thats why I always like my vent to stay on recycled!
  5. Oct 4, 2010 at 8:23 AM
    jrdbrn
    jrdbrn Borne Fishing
    Jared
    Louisiana
    '16 Inferno Tacoma TSS
    My truck did this for a while. It ended up stopping by itself.
  6. Oct 4, 2010 at 8:25 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    i've given up on controlling my HVAC system...the A/C and Vent always turns itself on and off...i think it might be my hand hitting the buttons when i shift sometimes, but i doubt it
  7. Oct 4, 2010 at 8:33 AM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    Let's be honest... you really only care about your own rig.
    HVAC at only 12 volts?
  8. Oct 4, 2010 at 8:36 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Yea, this was driving me nuts for a while, until someone told me to hold it down. Better than my getting mad and hitting the button harder and harder each time. :D
  9. Oct 4, 2010 at 8:38 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    i dont get what you mean
  10. Oct 4, 2010 at 9:03 AM
    Toyotacrawler
    Cusseta/Opelika AL
    Talked to the service manager at the dealer and he said that he has never heard of it cutting itself to fresh air automatically. Said that he drives a 2010 and has never had the issue that I'm having. Told him about holding the button down and he said that was news to him and to let him know if that works Haha! Gona give it a shot at lunch! Thanks guys! The info I get from TW is so much better than that of a dealer!!!
  11. Oct 4, 2010 at 10:53 AM
    Toyotacrawler
    Cusseta/Opelika AL
    Holding the button down 5 seconds fixed it! Thanks guys!
  12. Oct 4, 2010 at 11:04 AM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    Now time to inform the service manager!
  13. Oct 4, 2010 at 11:26 AM
    Toyotacrawler
    Cusseta/Opelika AL
    Done! :thumbsup:
  14. Oct 4, 2010 at 12:47 PM
    cinch
    Al
    Boulder Creek Ca
    Shows you what idiots some of the dealer employees are. The service manager doesn't even know how the HVAC works. I believe it tells you about the recycle button in the owners manual.
  15. Oct 4, 2010 at 12:51 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    anytime the temp outside is 50 degrees or cooler the rec will cut off unless you hold the rec button for 3 sec.
  16. Apr 27, 2014 at 7:00 AM
    Jose Collazo
    Jose Collazo Member
    Jose
    Puerto Rico
    06 prerunner
    None. Up to now. Probably considering doing some light modifications to increase hp. No idea how to get there.
    Good to know you've solved your problem. In my case (2006 2wd-pre-runner), the problem is with the motor which controls the air vent 'flap'. All if a sudden it started making a strange noise ('clicking'). It did not took much to notice that it was coming from the air vent motor (mechanism). I just turned off the "air exchange (lights off)'. Without doing anything else, just tried it several times, just to obtain the same results. Ended up removing the motor. I opened it and noticed that the main ''gear' had stripped some 'teeth'. I tried inverting it 180 degrees, but for some reason it would not work properly. Anyway, to make the long story short, looking for a replacement motor. Have done plenty of searches with no success. Any help will be greatly appreciated. It's quite annoying to go 'on the road' and all of a sudden start breathing 'carbon monoxide'.
  17. May 2, 2014 at 7:48 PM
    Jose Collazo
    Jose Collazo Member
    Jose
    Puerto Rico
    06 prerunner
    Hi to all. Just following up on my previous message asking for some information on the air vent control motor (located just behind the glove compartment).
    Appreciate any suggestion.\
    Best
  18. May 2, 2014 at 9:19 PM
    02Duck
    02Duck manuals make it better
    Oregon
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    I know exactly how you feel. There is a mod you can do to stop the automatic ac thing. It is very easy to do. After you have total control of the AC no matter where you have the vent aimed. Try searching for AC mod and it should come up. If I remember correctly it is just one wire you disconnect under the glove box.
  19. May 2, 2014 at 9:49 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Shouldn't be on recirc unless the AC is running anyways.
    Recirc increases the humidity and the potential for fogging the glass.
    The AC keeps the air dry.
  20. May 3, 2014 at 1:44 PM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    Never noticed mine doing that.
