WTS: 2000 Tacoma with Long Travel
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by teddygrahams, Jun 27, 2013.
  1. Jun 27, 2013 at 10:17 PM
    teddygrahams
    teddygrahams [OP] Well-Known Member
    A lot of parts I have replaced were precautionary measures to ensure the part didn’t fail and cause other issues.
    It is a 2000 Toyota Tacoma, 2.7 litter 4 clyinder prerunner. Contains Long travel front and rear. Not the prettiest truck on the street but it has all the goodies.
    $8600 Very Firm on price. I am located in Tustin feel free to texted or call before 9pm. 949-370-8162
    -The Truck
    1. 2 amps – x1 10” sub x2 front speakers
    2. Toyota TRD E-locker
    3. 4:56 gearing ratio
    4. LCE Headers with carb Sticker
    5. Cold Air intake with carb sticker
    6. Magniflow muffler
    7. Full professionally done roll cage
    8. Racing seats
    9. 5 point harness seat belts, also has normal seat belts for every day driving
    10. Air conditioner fully funtional
    11. Skid plate
    12. 13 inches of travel, front camburg bolt on kit. Sway-away coilovers with reservoirs. 4” bump stops that have been resized to 2”
    13. 12 inches of long travel in the rear with 7-pack deaver leaf springs. (took a leaf off to make it softer). Threaded body 14” sway-away reservoir shocks. Has 4” bump stops in rear
    14. 3.5 inch bulge fiberglass fenders front and rear.
    15. Bed cage with a small bed added in.
    16. 33” BFGs
    17. Rebuilt engine at 120k currently at 150k (had a blown valve, decided to do a full rebuild). Rings, Bearings, Honed cylinders, polished cam and crank, and replaced timing chain.
    18. New torque converter at 120k
    19. Synthetic oil changes every 8-9k
    20. No leaks on any of the shocks. Some rust on them due to long duration sitting (vehicle was inactive for 2-3 years because of the blown valvue).
    21. Racing center council so truck doesn’t pop out of gear during off-roading.
    22. 2.7 litter 4 cylinder.
    23. Sounds and runs excellent.
    -The issues with it
    1. Horn has some issues, works for a week then doesnt work for 3 weeks. Ive tried replacing relays and checked the wires(i think the compressor might be going out).
    2. Front tires at 25% and one of the causes the car to pull to the left.
    3. Has some cosmetic damage due to age/off-roading/people.
    4. Rear could be re-geared.
    5. head unit for stereo is dying
  2. Jun 27, 2013 at 10:20 PM
    banditstpk
    banditstpk Pabst knows best
    patrick
    buckeye arizona
    00 3.4L PreRunner TRD SR5 Xtracab
    deck plate, led lights interior, center hubs painted black,
    pics? price?
  3. Jun 27, 2013 at 10:25 PM
    teddygrahams
  4. Jun 28, 2013 at 8:54 AM
    Fiolo
    Fiolo Senior member
    1998 Tacoma, 2022 Tacoma, 2019 L5P Duramax
    Lost track many mods ago
    Might want to take some side pics
  5. Jun 28, 2013 at 11:25 AM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    spending a day repainting the cage and cleaning up those shocks would make your sale a lot easier. is the 4.56 gearing not a good combo with the 2.7 and 33's?
  6. Jun 28, 2013 at 12:32 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Thats OEM gearing ratio. But Ive driven a truck similar to this gearing and motor and tire size , lacks power and milage is ok.
  7. Jun 28, 2013 at 5:47 PM
    CliffordBRD
    CliffordBRD Well-Known Member
    Cliff
    Tampa, FL
    09 DCLB 4x4 Pyrite Mica
    Type of suspension setup?
  8. Jun 29, 2013 at 10:10 AM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    X2, would sell a lot faster if the paint looked fresh
  9. Jun 29, 2013 at 11:23 PM
    teddygrahams
    4:56 is not stock gearing ratio. 4:10 is generally the stock gearing ratio. The fenders were repainted recently. The bed cage has not be repainted recently.
    It does well with 4:56. Hill climbing it tends to lack. it could probably use 4:77 re-gearing or a turbo.
  10. Jun 29, 2013 at 11:24 PM
    teddygrahams
    been having some issues with the camera, ill try to get a side shot.
  11. Jun 29, 2013 at 11:28 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    on a 2.7l automatic 4 cylinder 4.56 is the stock gearing bro...
