WTS 2012 Furd F150 Papa Speed truck
Discussion in 'Buy / Sell / Trade - Other' started by Sleipnir, Apr 5, 2021.
  1. Apr 5, 2021 at 4:36 PM
    Sleipnir
    Sleipnir [OP] Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    Well I’m done folks. I’m throwing in the towel because I’m done messing with this truck. I ordered my second 7163 super core today and will be here this week and I will throw it on. I doubt I’ll finish tuning and will leave it up the the new buy but I can help you with introductions with @Boostking if you’re not a regular of his.
    Parts listed below and I will not part it out so don’t ask. I have an email confirmation I will send to the new buyer an email stating RMB Motor Works will replace both the toasted 7163 under his own dime. If I get the turbos they will go with the truck and new owner and I’ll will eat the cost of the $3800 I shoveled out for new ones already.
    Price is $35k which is more than fair considering what’s in it. I owe $17k on the loan and will take the rest plus another car I own as trade in on a new Ranger Tremor
    Current mods are as followed:
    Exterior:
    Nitto NV420V 275/55/20
    OEM Black Housing HID Headlights
    Stubby Antenna
    DIY Bedliner
    Moriomoto XB LED Fogs
    2014 Tremor 3 Bar Black Grille
    Interior:
    LED Interior Lighting
    Proclip Phone Mount
    SCT X4
    Motor:
    RMB Motorworks Stage 2 Short Block
    • Cylinder Block - Brand new Ford OEM bare block with a 92.50mm Stock Bore (Closed Deck)
    • Pistons - RMB-JE 92.75mm FSR Forged Pistons, Custom Ringset, .210" Steel Pins, Clips, (Coated Skirts and Offset Wrist Pins)
    • RMB Spec Gold Ceramic Piston Coating
    • Connecting Rods - Callies Compstar H-Beams with ARP 2000 Rod Bolts
    • ARP 2000 Headstuds
    • Rod / Main Bearings - King XP Bearings
    • Crankshaft - New Ford Gen2 Raptor Forged 2017+ Crankshaft
    • Main Bolts - Standard OEM 6 Bolt Mains
    • Compression Ratio: 10.0:1 STD Compression Ratio with STD .040" thickness head gasket
    Pocket Port-R Heads with conical spring kit, with Ti Retainers and locks and custom valves.
    XDI-35 HPFP
    Spec C Cam Lobe to increase HPFP by 25%
    Full Race- RMB EFR Twin Turbo Kit:
    • BRMS Crimped Racing hose upgraded
    • PTP Turbine Blankets
    • Charge pipes
    • Hot Pipes
    • EFR Manifolds
    • Turbine Blankets • EFR 71/63 T25 single scroll turbins with T25 in and 3" outlet to a true 3+ pipe
    • Black ceramic coated compressor housings
    • Black ceramic coat turbine housing upgrade for the forged case center section made form aluminum
    • Upgraded forged aluminum light weight turbo center-section
    Turbo Smart IWG-75 Waste Gates with 14LB Springs (B1 Single Scroll Housing (Double 7lb spring))
    Full Race V2 Intercooler
    Full Race V2 Radiator
    Radium Dual Catch Can
    Custom Blue Painted Valve Covers
    Setrab Oil Cooler
    RMB Remote Oil filter setup
    Trans:
    Stock
    CircleD 258mm 2B Converter
    Full Race Trans Cooler
    Exhaust:
    Full Race exhaust with resi
    Full Race EFR Downpipes
    Suspension:
    Rancho Shocks
    Fox 2.0 Coilovers
    Moog Upgraded Sway Bar Endlinks and Bushings
    Tuning:
    Boostking from EB forums
    https://imgur.com/a/ai5y3uq
    Biscuits likes this.
  2. Apr 6, 2021 at 7:01 AM
    brian.gonz
    brian.gonz Well-Known Member
    Brian
    Manor, Texas
    Supercharged 2012 TRD Sport DC
    TRD Supercharger, Relentless Fab Stingray, TRD Pro Wheels, BFG, AMP Research Runners.
    Any photos?
    Sleipnir[OP] likes this.
  3. Apr 6, 2021 at 7:08 AM
    Sleipnir
    I'm a horse
    Asgard
    Yea sorry thought I added them. Should be there now
  4. Apr 8, 2021 at 8:14 AM
    Sleipnir
    I'm a horse
    Asgard
    But new super core is in and running great
  5. Apr 8, 2021 at 12:44 PM
    Sleipnir
    I'm a horse
    Asgard
    Price drop. $24k come get it
