***SOLD*** *New In Box* Flex-a-lite 678 S-Blade Fan Kit
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by PapaBear, Mar 30, 2020.
  1. Mar 30, 2020 at 5:19 PM
    PapaBear
    PapaBear [OP] Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Brand new in box Flex-a-lite 678 kit for 2nd gen Tacoma.
    Bought new because I wanted to replace my stock clutch fan with an electric kit but things have changed and I’m going to keep the clutch fan and do a dual push fan setup on the front of the radiator instead.
    Only pulled things out of the box to take pictures, everything is there to install including the install instructions.
    According to Flex-a-lite, even though it only shows to work for a few years, this kit will actually work for 05-15.
    Asking $270 + split shipping, 48 only.
    Box SZ:
    22in x 18in x 5in WT: 14lbs
    806Taco likes this.
  2. Mar 30, 2020 at 5:51 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Is this so you can put the fan on a switch so when you ford water you don't blow it apart?
    I'm ignorant on this kind of thing.
    PapaBear[OP] likes this.
  3. Mar 30, 2020 at 6:17 PM
    PapaBear
    Austin
    SIN CITY
    I believe you can. The thermostat connects to a 12 line. You run the fan to the thermostat and the thermostat has a probe you stick into the radiator so the thermostat can read temp and turn on and off. I believe you can adjust the thermostat to your desired temp to kick the fan on, but I think I also read when purchasing it has connection in the thermostat box for a true on/off connection for a switch like you were saying.
    Slashaar[QUOTED] likes this.
  4. Mar 31, 2020 at 4:59 PM
    PapaBear
    Austin
    SIN CITY
    Bumpski
  5. Apr 4, 2020 at 12:18 PM
    PapaBear
    Austin
    SIN CITY
    Bumps
  6. Apr 7, 2020 at 6:01 AM
    Superloki24
    Superloki24 Well-Known Member
    Windsor, ON
    '14 X-Runner
    TRD SC, TRD CAI (Gen 1), Full URD Spec-U Exhaust, UCON EMS, , URD Lightweight Steel Flywheel, URD Stage 3, URD Trac Bar, OEM Oil Cooler, Detroit Tru-Trac, Truxedo Titanium Cover, 76mm Throttle Body, XII Performance drop, QA1 Rear Shocks, 4x4 Rear Leaf Springs.
    I looked on their website and they say that it will fit a '12 Tacoma, but any idea if things changed for the '14 Tacoma that would make this kit not fit?
  7. Apr 7, 2020 at 1:14 PM
    PapaBear
    Austin
    SIN CITY
    Honestly not that I know of. I mean the only major changes I know is the addition of the carb air pump but that is up in the passenger fender well and the swap to hydro booster instead of vacuum booster for the brakes. Besides that, dimensions look to be the same. Radiator size is the same. I can’t confirm or deny, but I would think maybe something needs to be modified to fit, but I don’t think it would be anything major. Are you interested?
  8. Apr 8, 2020 at 11:40 AM
    Superloki24
    Windsor, ON
    '14 X-Runner
    I confirmed with Flex-a-Lite Tech Services and they said that they just haven't updated their website to include the '12-'15 models. It will fit they said.
    I can't commit to it yet. Funds aren't available at the moment, but maybe in a month or so. Hopefully you still have it by then....
  9. Apr 9, 2020 at 5:39 PM
    PapaBear
    Austin
    SIN CITY
    I am interested in trades. Any firearms or ammo?
  10. Apr 13, 2020 at 5:34 AM
    Superloki24
    Windsor, ON
    '14 X-Runner
    Man I would trade up some guns but getting them across the border might be an issue.
    PapaBear[QUOTED][OP] likes this.
  11. May 1, 2020 at 8:37 PM
    PapaBear
    Austin
    SIN CITY
    bumpskis
  12. May 4, 2020 at 9:22 PM
    PapaBear
    Austin
    SIN CITY
    bumpskers
  13. May 9, 2020 at 1:49 PM
    PapaBear
    Austin
    SIN CITY
  14. May 14, 2020 at 7:25 PM
    PapaBear
    Austin
    SIN CITY
    Bumpers
    Redsyota likes this.
  15. Jun 2, 2020 at 2:45 PM
    PapaBear
    Austin
    SIN CITY
    Price changed, bump
  16. Jun 15, 2020 at 1:04 PM
    PapaBear
    Austin
    SIN CITY
    BUMPS. PRICE drop. $270 + split shipping cost, 48 only.
  17. Jun 16, 2020 at 1:16 PM
    Steawy27
    Steawy27 Well-Known Member
    Mark
    2015 tacoma
    Pm me
  18. Jun 17, 2020 at 4:30 PM
    PapaBear
    Austin
    SIN CITY
    pmed you
  19. Jun 27, 2020 at 4:20 PM
    PapaBear
    Austin
    SIN CITY
    Bumps price changed
  20. Jun 28, 2020 at 3:14 PM
    PapaBear
    Austin
    SIN CITY
    bumpers
