WTT: 1986 Porsche 944 Turbo for 2nd Gen
Discussion in '2nd Gen Tacomas For Sale (2005-2015)' started by drew944, Jun 29, 2016.
  1. Jun 29, 2016 at 7:58 AM
    drew944
    drew944 [OP] Member
    Drew
    Apison, TN
    1986 Porsche 951, 1979 HJ45 Troopy
    Kind of an odd ball trade, but I'm looking to trade my 1986 Porsche 951 for a2nd gen. I would like it to be 4wd, 6 cylinder, and at least an access cab. Manual trans is a plus but not a deal breaker.
    About my car:
    It's the third 944 I've had and by far the best in both condition and performance. Unfortunately, it does not fit my lifestyle right now and so it must go. Looking for $10,500 OBO. Car is located in Chattanooga, TN.
    The Good:
    Front Suspension:
    Koni double adjustable shocks with M030 threaded collars (coil-overs)
    KLA Billet Monoball upper strut mount
    Racer's Edge upper hat and lower seat
    Hypercoil 350lb springs
    Rebuild control arms with lowering race spindle pin
    968 M030 updated caster blocks
    Turbo S M030 28.5mm Front sway bar with solid center bushings
    Rear Suspension:
    Koni Coil-overs with Hypercoil 450lbs springs
    Racer's edge upper hat and lower seat
    18mm adjustable rear sway bar with solid bushings and drop links
    Tie down eyes on rear shocks (easy transportation to track)
    Misc:
    Corner Balanced
    Reinforced torsion tube carrier
    Aggressive Alignment
    Engine:
    Rebuilt ~30k ago, at which time the Lindsey Racing 340 RWHP kit was installed.
    Rebuilt Head and converted to spring loaded Tensioner within the last month.
    Passed Emissions in Hamilton County TN with no issue.
    Wheels:
    BBS RS 16 x 7's and 8's
    Tires:
    205/55R-16 Bridgestone RE-11
    255-/50R-16 Bridgestone RE-11
    The Bad:
    Clear is peeling in some areas and paint isn't in perfect shape (rock chips, etc)
    Broken Fog Light Cover (Happened unloading car from trailer)
    Missing one seat adjustment button
    Typical 944 stuff (cracked dash, odometer not working, hatch seal, sunroof not working)
    AC condensor is MIA. PO had a new radiator installed but left the condenser off.
    Odometer shows ~183K and I do not think that is very far off. PO replaced it with a GT3 and it sat until the HOA decided it should go. A well know 944 mechanic in the Nashville area got it and went through it before I bought it, so belts, water pump, and rollers are all taken care of (new in October)
    Overall the car is very solid. I purchased it in October to be my daily driver and in December the stud that the tensioner mounts to gave up the ghost. I had the head repaired and had it upgraded to the later, spring loaded tensioner. In the time that the car was out of commission, I changed jobs and this car won't work for what I need. It drives great, boost feels good, and handles like it is on rails. I have receipts for suspension and engine work that total to around 15K. This would be a great weekend car, DE car, track car, or DD if you don't mind a little more racy ride. The factory sport seats are awesome. Supportive where you want it and cushy where you don't.
    I will have some more pictures tomorrow, I ran out of daylight today. I also have a stack of receipts if you want them and am happy to give you my mechanic's name and number to answer any more questions about the car.
    Link to pictures: https://www.flickr.com/photos/63735168@N08/albums/72157667603228914
