WTT: 4.56s for 3.73s
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 92LandCruiser, Feb 21, 2013.
  1. Feb 21, 2013 at 9:16 AM
    92LandCruiser
    92LandCruiser [OP] Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I'd like to find someone local-ish to swap gears with.
    Paid $1374.50 from ECGS + cores
    now they've gone up - 30$
    4.56s solid sleeve
    e-locker/open
    $900 plus trade for low mileage stock 3rds and I will help with swap - has to come to me.
    rear pinion is barely seeping gear oil haven't heard anything from ECGS -- been a couple weeks now :/
    Think they fucked the seal up.
    Not many miles on the rear and it's less than a year old. The front is around 2 years old with ~20k miles on it.
    3rds are in truck, need to swap everything same day.
  2. Feb 21, 2013 at 9:52 AM
    Large
    Large Red
    Make a road trip to Houston :spy:
  3. Feb 21, 2013 at 11:30 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Dood, you're like a month too early :anonymous:
  4. Feb 21, 2013 at 5:33 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Push er up a couple weeks Matt!
  5. Feb 21, 2013 at 6:37 PM
    la0d0g
    trying, getting a 'big' tire put on my spare wheel this week. Then I'll know what needs to be cut :)
    I'll keep you posted as I'm definitely interested
  6. Feb 21, 2013 at 7:09 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Cool sounds good man!
  7. Feb 22, 2013 at 6:40 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    i still have my stock gears from my rear 3rd...would need install pack though...
    doesn't exactly help you, but if you need them we can work something out i'm sure
  8. Feb 22, 2013 at 6:47 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Why max why
  9. Feb 22, 2013 at 9:46 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Thanks Bob, I'll keep it in mind. :eek:
  10. Feb 22, 2013 at 9:47 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Because Land Cruiser :cool:
  11. Feb 22, 2013 at 9:48 AM
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    make a trip to VA and we have a deal
  12. Feb 22, 2013 at 9:54 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Hah, sorry dude! You'll have to pay full price from ECGS! :p
  13. Feb 22, 2013 at 11:58 AM
    Spoonman
    Jamie
    Alberta
    Diesel? Yeah!!
  14. Feb 22, 2013 at 6:03 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Damn right Diesel
  15. Feb 22, 2013 at 6:08 PM
    jandrews
    '09 FourDubDee TRD OR
    Re: pinion seal leak:
    I had the same thing on mine when filling to level with the fill hole with 85-140w. I think at temperature the heavier weight oil acts like a pretty gnarly overfill and pushes oil past the pinion seal. And no, my diff breather isn't clogged, but it is relocated, meaning a longer hose with more air resistance inside it.
    You running 85-140? If you are, try underfilling it about .25 quart to compensate for the heavier weight. I did this and haven't had the issue since.
    Oh yeah...and why you lookin' to offload your geared diffs? New plans?
  16. Feb 22, 2013 at 7:04 PM
    Spoonman
    Jamie
    Alberta
    85 140?? I put in regular 80w90 like Toyota suggests
  17. Feb 22, 2013 at 7:44 PM
    jandrews
    Toyota specs 75-90. ECGS recommends 85-140 for hard use.
  18. Feb 23, 2013 at 12:09 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I'm running 80w-90 because it's cheap and easy to find. Thanks though man, I'll check the level this weekend regardless.
    Traded 35s for 33s, trying to take the Taco back to a cheaper configuration and one that may be easier to sell in the future while putting some cash in my pocket now.
    ...because I bought a 1992 80 series Land Cruiser.
    Plans are:
    12 valve cummins, NV4500 trans, NP205, 60/14bolt, 3 link/leaves
  19. Feb 23, 2013 at 4:28 AM
    jandrews
    Have fun with the 80.
    I'm thinking next build needs to start with me just bending tube and frying it together until there's a chassis there. That's a few years out though.
  20. Feb 23, 2013 at 11:22 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Thanks John!
