WUD WUD WUD Vibrations
Discussion in 'Technical Chat' started by Chickenmunga, Aug 16, 2010.
  1. Aug 16, 2010 at 4:51 PM
    Chickenmunga
    Chickenmunga [OP] Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Since lifting, I've had the following issues:
    -small "hopping" feeling around 10mph when accelerating from a stop
    -very small audible vibration at 60mph, I think I feel it more from the pedal than anywhere. I don't feel it from the steering wheel.
    I'm not really worried about that. However, I've been noticing a stronger vibration lately between 55 - 70, being the strongest at 60 (I don't really drive faster). It sounds like a WUD WUD WUD sound. Again, I don't feel it in the steering wheel. It doesn't feel the same each day - I think it's more pronounced when the vehicle is fully warmed up, but I haven't been driving it lately to know. It goes away when I let off the gas.
    Dad thought it was bad wheel bearings or loose lugs, but we tried shaking the tires back and forth and they didn't make any clunking noises - plus there's no issues at the other speeds.
    Should I worry?
    Truck Details:
    3" OME lift
    Driveline spacer
    stock tires
  2. Aug 16, 2010 at 4:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    how much of a driveline spacer did you use?
  3. Aug 16, 2010 at 4:58 PM
    Chickenmunga
    Keizer, Oregon
    It's the OME FK29 that comes in the kit that Wheeler's sells. I can measure once I get home if needed.
  4. Aug 16, 2010 at 5:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    let me know what size the spacers are.
  5. Aug 17, 2010 at 1:37 AM
    Chickenmunga
    Keizer, Oregon
    Sorry, I got busy on some other projects. :eek:
    It looks to be 1/4"
  6. Aug 18, 2010 at 10:16 AM
    Chickenmunga
    Keizer, Oregon
    No clues? :(
  7. Aug 18, 2010 at 2:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you could try adding an extra 1/4 worth of spacers to make it half inch..see what that does. sounds to me kinda like something is binding.
  8. Aug 18, 2010 at 3:14 PM
    Chickenmunga
    Keizer, Oregon
    Got any tips where I can pick up some more spacers for testing? I know you make some and there's wheeler's, but both of those options would take longer than a simple trip to the store.
    Would it have anything to do with balancing?
    I would have tried checking for a bent rim, too, but these are the stock aluminum (aluminum cracks and I'd be having much bigger problems at 60mph!)
    I'm going to try checking to see if there's any parts behind the wheel that look odd.
    Tires didn't look bubbled anywhere but it's worth another inspection in case I missed it - highly doubt it unless it's on the inner side.
  9. Aug 18, 2010 at 7:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    could be the way they are balanced.but.....if not....let me know. i'll send you a set of 1/4 inch spacers for you to try out.
  10. Aug 20, 2010 at 8:11 PM
    Chickenmunga
    Keizer, Oregon
    Took it to the dealer today, and they are pretty baffled. Apparently the tech and the advanced tech came up empty. I'm scheduled to have the master mechanic look at it in 2 weeks when he gets back from vacation
    On a separate note, they did the computer reflash while it was there :) I didn't have a prob with that before, but it's a nice peace of mind.
    thanks for the offer, I might take you up on it if this doesn't pan out.
  11. Aug 20, 2010 at 10:39 PM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    I had the same thing happen to me -- it got progressively worse. It turned out the there was a defect in one of the tires and in one spot the outer shell stated to delaminate from the inner carcass. I finally figured it out when it failed. I replaced the tire and the wud wud wud was gone and never came back
    I seen it happen one more time on a co-workers car -- it looks like a blister/bubble on the tire. When it first starts out you won't even notice it unless you inspect it closely. As it progresses it becomes more noticeable
  12. Aug 21, 2010 at 12:33 AM
    Chickenmunga
    Keizer, Oregon
    Yeah that was my first guess. I had them check tires, then balancing. They say they are positive that tires are OK.
  13. Sep 2, 2010 at 11:19 AM
    Chickenmunga
    Keizer, Oregon
    So I took the truck in today for the master mechanic to look at. He called me back and said he found the issue. Apparently my bearings went out in the rear differential! He said it's a rare occurrence, and they are replacing the whole rear diff under warranty :)
  14. Sep 2, 2010 at 11:51 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Not too rare.... check out the 05+ Tacoma failed rear end thread on TTORA and you'll see.
  15. Sep 2, 2010 at 2:35 PM
    Chickenmunga
    Keizer, Oregon
    I think that's slightly different, but I went ahead and asked there anyway.
    So, do I have to break in the new rear again as if it was a new vehicle? EDIT: Service shop says no.
  16. Sep 7, 2010 at 9:46 AM
    Chickenmunga
    Keizer, Oregon
    Right, so I got the truck back Friday. Brand new rear diff.
    The invoice says, "excessive clearance in front pinion causing damage to ring gear op #410101 T-1-91 T-2-43=2.4 test drive OK"
    While I was there, I noticed that the Tualatin Valley Fire & Rescue had their FJC in for the same repairs. Theirs had actually gone in for the issue once before in Utah, but Utah did a shoddy job (didn' put things together well, used slilicon instead of gaskets) and this time it grenaded.
    Anyway, I drove my truck from the dealer to the highway and went 4 miles. I noticed that the same issues came back, but were a bit muted.
    I drove straight back and dropped the truck off for the weekend. Got a call back today, they say that they noticed the same. They disconnected the rear diff and put it in 4WD (essentially making it a front wheel drive) and said that the vibes go away.
    I guess we chalk this up to the lift? I had the driveline spacers since day 1 of the lift.
