www.gaugeplates.com
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Gunner, Aug 6, 2010.
  1. Aug 6, 2010 at 10:21 AM
    Taco Gunner
    Taco Gunner [OP] Well-Known Member
    Arizona
    2006 Access Cab TRD Offroad
  2. Aug 6, 2010 at 10:23 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Check out metamiller... he does awesome work and has been serving tw for quite a while.
  3. Aug 6, 2010 at 10:27 AM
    BSPDX
    BSPDX Well-Known Member
    Looks like cleaner work than metalmiller tho... His work is raw and needs a ton of work to be in a finished state, I wouldn't recommend.
  4. Aug 6, 2010 at 10:41 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Pretty cool, I'm looking to install a gauge and some switches, this certainly gives me some ideas!
  5. Aug 6, 2010 at 10:44 AM
    Taco Gunner
    Arizona
    I hate finding this stuff...I want to start adding random switches!
  6. Aug 6, 2010 at 10:48 AM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    metal versus acrylic, fake chrome....no comparison dude.
    i would recommend metalmiller over this plastic crap any day!! plus you are very limited on what they will do...no copyright stuff...
  7. Aug 6, 2010 at 10:51 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    x2 ^^^^^^^
  8. Aug 6, 2010 at 11:00 AM
    BSPDX
    I did buy his crap once... and only once! I said the plastic looked cleaner... If someone wants to install out of the box and ready to roll this stuff looks like it would work great. If you want to do your own fabrication, sanding, paint, clear or whatever after paying a guy to make an initial raw cut then metal miller may be for you... I was overcharged for a rusty bent up POS emblem that I had to put about 6-8 hours into before it was acceptable. I wouldn't recommend him, but I'm sure plenty would.
  9. Aug 6, 2010 at 11:01 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    x3
  10. Aug 6, 2010 at 11:03 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    He sold you the product exactly as he advertised... I don't see how you can complain about a product you didn't fully research. Sorry you feel that way.
  11. Aug 6, 2010 at 11:11 AM
    BSPDX
    My first emblem didn't fit because he didn't cut it properly so I had to send it back & wait a few weekd for him to correct it! Then I had to heat it up a new one with a torch to bend it back, then I had to grind and sand several edges and retap one of the threads as he stripped it, then I bead blasted it & then finally was able to get it powdercoated... It wasn't advertised as that much work... That was unacceptable!!
  12. Aug 6, 2010 at 11:12 AM
    Taco Gunner
    Arizona
    Ok....can we move on?
