Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 22, 2016 at 10:02 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you going to drill a hole in your roof?
  2. Mar 22, 2016 at 10:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Good looking radio.
    And is that not where you guys are going? Have you not been planning anything?
  3. Mar 23, 2016 at 5:48 AM
    FIRTH4X4
    FIRTH4X4 Well-Known Member
    Eric
    Wyoming
    98 Taco 2.7L 5spd
    Howdy from the beautiful Star Valley in Afton, WY.
    joshipps likes this.
  4. Mar 23, 2016 at 6:12 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    :wave:
  5. Mar 23, 2016 at 6:17 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Welcome!
    A 1st gen reg cab! Cool
  6. Mar 23, 2016 at 6:24 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    :spy: I want to go
  7. Mar 23, 2016 at 8:59 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Of course it is. Typical Ben drama. :rolleyes:
    I am thinking an early fall run to moab might be appropriate. After the heat of summer.
    Why that particular radio (other than Mr Tim recomended it). Price? Availabliity? Functionality? Ease of install?
    Is it APRS or DPRS? :stirthepot:
  8. Mar 23, 2016 at 9:06 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    That would work for me. Plenty of time to sort things out still and the weather should be perfect. Keep me in the loop.
    Digiratus[QUOTED] likes this.
  9. Mar 23, 2016 at 9:13 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Ill help u drill it. By that i mean i will watch so that when my time comes i will have seen it done.
  10. Mar 23, 2016 at 10:02 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's aprs. Dprs is only on icom radios that use dstar network.
    So moab this year Huh not Canada?
  11. Mar 23, 2016 at 10:15 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Are you saying you are interested in going back to Canada? I am, if you are. We get a 30% discount on our monies in CA right now.
  12. Mar 23, 2016 at 10:19 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, mid-80s instead of 100+
  13. Mar 23, 2016 at 10:31 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I thought you would go back. But idk. I don't care. As it stands right now. I'll be in wyo/mt this summer
  14. Mar 23, 2016 at 10:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Depends on when you're going.
  15. Mar 23, 2016 at 10:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. I just thought mike was for Canada and you where for moab. I didn't know what you guys where thinking.
    IDGAF where we go. Where we go will only affect which truck I bring.
  16. Mar 23, 2016 at 10:36 AM
    Digiratus
    Roaming the PNW
    The RedHead
    IDK. I can't tell. o_O
    For Canada, what works best for you?
  17. Mar 23, 2016 at 10:37 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    In terms of timing?
    I work the Montana gig June-July. August-sept is weed spraying.
  18. Mar 23, 2016 at 10:41 AM
    Digiratus
    Roaming the PNW
    The RedHead
    It wouldn't be before July for me. August is the earliest time I can get away for more that weekends. Are you willing to take two weeks away from your weed spraying gig?
  19. Mar 23, 2016 at 10:47 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No probably not. Couldn't say at this time anyways. It's possible the season would end early sept. But I will need the $1000+ bucks I make from 2 weeks for moving again.
  20. Mar 23, 2016 at 11:01 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I've been thinking about two adventures actually. :p I have the vac time if the truck will hold together.
