Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 24, 2016 at 9:09 PM
    at_olw
    at_olw Banned in D.C.
    if you had bought the radio from a real ham radio store, like I said, then you'd see the separation kit listed:
    http://www.gigaparts.com/Product-Lines/Remote-Cables-Kits/Kenwood-DFK-3D.html
    http://www.aesham.com/product/ham_radio_accessories/ham_radio_accessories_mounts/kenwood-dfk-3d/
    http://www.hamradio.com/detail.cfm?pid=H0-008952
    You can even pay more on Amazon if you want:
    http://www.amazon.com/Kenwood-DFK-3D-Remote-Mount-TM-V71A/dp/B002H6XNYA
    Not true.
    DPRS is such a waste. I think you're referring to DSTAR, which is different.
    To answer your question Mike, this is more or less right. For the money, it's the best thing out there for an analog dual band rig. It's fairly easy to add aprs functionality should it be desired, and arguably Kenwood's are the only radio's that meet the fcc requirement for crossband repeat. It's a great first radio to start out with, and what I wish I still owned. I made the mistake of selling mine to @92shawman. Although, I am glad it ended up with a friend who has gotten into the hobby as well.
    Nothing is glued. You don't need to drop the headliner to install a NMO. They're designed to be installed from the top. You don't need to sand anything to get a good ground; the mount has "teeth" that will cut through the paint to contact metal, similar to how star washers work.
    You only need to pull the a and b/c pillar trim panels on one side of the vehicle (the side you want to run the cable, and side of the seat you're going to install the radio under). This will allow you to pull the headliner down far enough to fish the cable out.
    A word of caution: Make sure you drill the hole such that it does not go through the spiderweb of reinforcement panels, or you will have a miserable time making it waterproof. Use an appropriate punch or step drill, and use masking tape around the hole, with a ridge shaped like a mini volcano to catch loose shards. Otherwise you will scratch the fuck out of your clear coat trying to brush the chips off your roof. Locate the hole in the center of your roof, to minimize directional bias. For a 2m antenna you ideally want at a minimum 19.685" R circle around the antenna. Mine's slightly towards the rear to reduce the unicorn look, though. But that was mostly to avoid a crossmember.
    All said and done the install takes ~1hr. You could do it in half the time if you're not terribly neurotic.
    92shawman likes this.
  2. Mar 24, 2016 at 9:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Where would you locate the radio if not under one of the seats? Right now I have an amp under each seat.
  3. Mar 24, 2016 at 9:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Looks like buying that kit from Amazon is still cheaper becuase free shipping. Giga Parts at least want almost $12 for shipping so it ends up about $5 more than Amazon.
  4. Mar 24, 2016 at 9:34 PM
    at_olw
    Probably under your fridge. You've got unused space under it between the cubby and amp, right? The general criteria is an area that maximizes airflow and minimizes dust buildup, ideally out of direct sunlight. There are plenty of decent enough locations - attached to the rear of the center console, under the dash, attached to the back of the seat, etc.
    If he had bought everything from them, then the shipping would have been free, and all of the unit prices would have been less.
  5. Mar 24, 2016 at 9:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    OK. Thanks. I guess it'll depend on its dimensions.
  6. Mar 25, 2016 at 3:16 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
  7. Mar 25, 2016 at 5:07 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
  8. Mar 25, 2016 at 6:25 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Noice!
  9. Mar 25, 2016 at 6:29 PM
    justinf307
    justinf307 Well-Known Member
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    I'll get mine ordered tonight!
  10. Mar 25, 2016 at 6:35 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Sucka! I'm very happy with it.
    Another bit of advice for catching metal shavings before they scratch your paint: tape newspaper down around the hole.
    Hardest part is getting past drilling a hole in your cab!
    at_olw[QUOTED] likes this.
  11. Mar 25, 2016 at 8:24 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    He's not the only reg cab! I just don't come around here often. Mostly I just lurk.
  12. Mar 25, 2016 at 9:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well stop doing that! Join in the convo :D
    :wave:
  13. Mar 26, 2016 at 10:26 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    @FreidTaco @justinf307
    Relentless wants you two to PM him and give consent for me to receive your orders.
  14. Mar 26, 2016 at 10:42 AM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    After the first dent drilling a hole is nothing :anonymous:
  15. Mar 26, 2016 at 10:50 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Me neither :cookiemonster:
  16. Mar 26, 2016 at 11:25 AM
    FreidTaco
    FreidTaco boost
    jeff
    Done
    BossFoss[QUOTED] likes this.
  17. Mar 26, 2016 at 7:12 PM
    TRVLR500
    Wyoming
    I'll see what I can do. I don't really have a whole lot to add. Mine is a DD although I did take it out today and go exploring so it's dirty now. You'll probably hear more from me in another year or so when I want to get out and start exploring northern Wyoming when I have the time. I'm down here in Green River and at this point in time serious wheeling isn't something I want to do with a DD. This area is quite boring. I know the best is up north.
  18. Mar 26, 2016 at 7:15 PM
    TRVLR500
    Wyoming
    I just picked up a shortwave receiver (Icom IC-R75). Can't get shit on it so far. I know it needs a ground and a good antenna. In any case, where did you mount a ham in your truck? I look at the inside of mine and have a hard time figuring out where I'd even put a CB. There's no extra room anywhere.
  19. Mar 26, 2016 at 7:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    replacing the Ashtray with a Uinden 520xlpro CB is the best place for a CB.
    Ham radios, mobile units anyways, usually have separate head units. So you can mount the radio under the seat and then the face plate just bolts to the dash somewhere.
  20. Mar 26, 2016 at 7:24 PM
    TRVLR500
    Wyoming
    Ok. That makes sense.
