Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 26, 2016 at 8:02 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    Well, it looks like it works there. Options are severely limited in these truck. Mine has a bench seat so there isn't even a console.
  2. Mar 27, 2016 at 7:34 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Do you have any more pics of the antenna install process? Which antenna is that? Link?
  3. Mar 27, 2016 at 8:20 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
  4. Mar 27, 2016 at 8:37 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Saw the cruiser. If I had money I would pick it up and make a good looking, complete cruiser out of the two.
  5. Mar 27, 2016 at 9:07 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks for the link Ben, Looks like it is from gigparts anyways and is offered with free shipping. :notsure:
    So, no other pics of the antenna install process I take it?
    I've taken the rear side panels off before when I installed the rear speakers so have a pretty good idea of what is involved there. I have the seats out now anyways because I am redoing the power wires for the amps and the fridge. Gonna reroute them to the battery in the bed.
    How did you know where to drill the hole for the antenna base? Mr Tim spoke of avoiding webbing/reinforcement that must be on the other side of the metal, was it from looking between the headliner and the roof that you were able to see where to drill?
    Is the antenna not detachable from the base when not in use? Hmmm. I want to be able to get inside the garage and my opening is lower than yours. Not sure I want to make that compromise. How flexible is it? Is it really stiff?
  6. Mar 27, 2016 at 9:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You can get antennas that fold over. My dads does.
    id buy that cruiser just for the rear axle at that money
  7. Mar 27, 2016 at 9:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    With a permanent base? Do you know what he has?
  8. Mar 27, 2016 at 9:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea it has the same exact mount.
    No i don't. Im sure he doesn't get on here anymore either haha
  9. Mar 27, 2016 at 9:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Changing the set screws can also change the antenna tuning i believe...
  10. Mar 27, 2016 at 9:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    They aren't. Trust me. You'll want to tune it.
  11. Mar 27, 2016 at 9:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, I haven't seen him post in a long time. Do you think it is a Larsen antenna?
    Are you implying that removing it via the set screws is bad for this reason?
  12. Mar 27, 2016 at 9:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea i wouldn't be surprised but honestly...no clue.
  13. Mar 27, 2016 at 9:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The length of the antenna changes. And thats how you tune it.
  14. Mar 27, 2016 at 9:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    @m3bassman
    I don't understand your comment about have to park outside if it is as flexible and floppy as you say?
    And yeah, the house battery is going in the driver side front corner of the bed.
  15. Mar 27, 2016 at 9:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ham antennas are not flexible. They are rigid steel. Smacking them around actually makes them work worse too so banging them on trees isn't great. Not gonna have to replace them for a long time but still.
  16. Mar 27, 2016 at 9:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well its not a wire whip by any means. You wouldn't drive into the garage with it now would you? its not a CB antenna with a spring
  17. Mar 27, 2016 at 9:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Sounds like I might be better off with one that folds down. The Princess RedHead has to live in the garage. :rolleyes:
    Kind of a dilemma. Needs to be on the roof for better performance, but can't hold up to the abuse it'll receive on the roof.
  18. Mar 27, 2016 at 9:49 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Wait, what? Are you saying now that you can park in your garage? That all you have to do is unscrew it from the base? And because it is kind of a hassle, you are not going to, even tho it means the Guac has to live outside?
    Ben, would you mind snaping a few pics tomorrow of what everything looks like detached, both the base and the antenna.
  19. Mar 27, 2016 at 9:55 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ok. I feel mo betta about getting one then.
    This is a new trend... Me copying you. :rofl:
    Blackdawg[OP] likes this.
  20. Mar 27, 2016 at 10:06 PM
    VLocos24
    VLocos24 Well-Known Member
    just moved to Cheyenne from Southern Cali. whats up guys!
