Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Apr 13, 2016 at 8:18 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    92shawman, at_olw and Speedytech7 like this.
  2. Apr 13, 2016 at 8:25 AM
    Member1Zillion
    Member1Zillion Involuntary Kamikaze Co-Pilot
    Big Whiskey, WY
    '01 TRD, '17 Tundra, '07 FJ Cruiser, 94 PU, '18 T4R, '84 PU
    This, that, & the other thing
    Yeah I used to live on the other side of the Cascades, so I know what you're getting there too. The CalChlor doesn't seem to help much and leaves this powdery white residue on everything it touches. I think over long periods of time without washing it off, it actually eats into steel. It definitely takes the clear coat off of aluminum or alloy wheels. Not sure how much salt they are using, but it's not enough, so it doesn't work well. I wish they'd just go back to using the sand or just plowing. Most people here have 4 wheel drives and we don't get sh!t for snow anymore anyway so just go back to the way it was. Glycol is basically unpurified antifreeze, so no wonder it's sticky or syrupy.
  3. Apr 13, 2016 at 10:03 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Where they going?
  4. Apr 13, 2016 at 10:03 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Moab
  5. Apr 13, 2016 at 10:05 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nice. Jealous
    Digiratus likes this.
  6. Apr 13, 2016 at 10:07 AM
    Speedytech7
    Ditto!
  7. Apr 13, 2016 at 10:18 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Today is travel day if I'm not mistaken.
  8. Apr 13, 2016 at 10:19 AM
    Speedytech7
    Can't say I know for sure, lemme check my texts pretty sure Ben said something to Josh and I.
  9. Apr 13, 2016 at 10:19 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wish I could do that. It's weird to think about my future at this point. Not sure I'll be able to do trips at all hardly.
  10. Apr 13, 2016 at 10:20 AM
    Speedytech7
    You'll get there, once you're into a routine you find time you didn't know about.
  11. Apr 13, 2016 at 10:22 AM
    Speedytech7
    After looking at my texts, I'm still not really sure, Ben is a bit confusing to txt. Think you're right and they're on the road now.
    EDIT: Apparently it is Saturday...
  12. Apr 13, 2016 at 10:22 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I hope this isn't totally true. I know your options are going to be more limited now, but I think you'll still need to stand on that mountain top, away from the crowds.
  13. Apr 13, 2016 at 10:30 AM
    Digiratus
    Roaming the PNW
    The RedHead
    When are you heading out? Tomorrow?
  14. Apr 13, 2016 at 10:31 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    You find the time. You already have a built rig so the easy part is done. While I'm sure money will still be spent on it, it doesn't require a large amount to get anywhere serious (stock to say where I am now) plus what it would cost for the actual trip funds.
  15. Apr 13, 2016 at 10:37 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's true. But I won't have Frank with me for...idk when. That's a problem haha
    Time will tell.
  16. Apr 13, 2016 at 10:43 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Smooth dirt road in moab has killed a taco every year in moab since 2012...don't be the 2016 one
  17. Apr 13, 2016 at 10:45 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    what happened to the dash!
  18. Apr 13, 2016 at 10:47 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    friday
  19. Apr 13, 2016 at 11:18 AM
    Member1Zillion
    Big Whiskey, WY
    All the cool kids are doin' it! Just quit whatever pathetic thing you're doing and go!! LOL
  20. Apr 13, 2016 at 12:00 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    All about balance. Sometimes taking a pay cut to be able to have more free time is worth it. Depends on what you value in life I suppose.
