Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Apr 16, 2016 at 11:52 AM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Who has the red access cab in Laramie again? I forget his username but damn, its looking good! The bed rack is clean. The gal and I were in the cruiser and went into snowies gas station but only saw middle schoolers.
  2. Apr 16, 2016 at 5:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hmm. I don't remember either. Wasn't very active.
  3. Apr 16, 2016 at 9:48 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    @SconnieHailer Finally got the Foxes installed. Nothing to report yet as only went around the block a few times. More feedback coming.
    Only a little drama. Had some trouble getting one of the billies off. The sleeve inside the lower bushing welded itself to the thru bolt. Had to modify it slightly to get it off. :eek:
    Any one need a set of 9.25" 5125s? :D
    Blackdawg[OP] and SconnieHailer like this.
  4. Apr 17, 2016 at 10:37 AM
    Hashc93
    Hashc93 Well-Known Member
    I put on my lift kit no problem and took the truck to big O tire in foco for my alaignment 69$ got everything in spec for the most part. They tired to tell me it was 2500 for new UCAs all I could do was laugh in his face and call him an idiot. My question is now what UCA to get? I feel comfortable installing them but just don't know about brands. I saw a all pro group buy that was about 560 for both. I do some occasional off roading but no crazy rock climbing type stuff. Just want quality parts for the truck. Thanks
  5. Apr 17, 2016 at 12:29 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    What a difference 11 days makes...image.jpg image.jpg image.jpg A certain gold Tacoma has camping fever.
    VLocos24 and SconnieHailer like this.
  6. Apr 17, 2016 at 2:19 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What are the details on your truck? 1st gen or 2nd? What kit did you use to lift the front and rear?
  7. Apr 17, 2016 at 2:31 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    How's that Wyoming saying go. If you don't like the weather when you walk out the front door then go out the back door. :cookiemonster:
  8. Apr 17, 2016 at 3:42 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    only 7 mos of mild winter left, until real winter begins again...
  9. Apr 17, 2016 at 3:50 PM
    Hashc93
    Yes that might be important info.
    Ome 885s and 5100s at 0 second gen 06 double caB short bed
  10. Apr 17, 2016 at 6:09 PM
    Digiratus
    Roaming the PNW
    The RedHead
    My 2nd gen math ain't very good. How much lift is that in the front? What all did you do for the back?
    Maybe some of the more experienced 2nd gen guys will offer up some advice for you on UCAs
  11. Apr 17, 2016 at 6:29 PM
    jgantzler
    jgantzler Well-Known Member
    Jeremy
    The jba ones look decent, and seems like they have been getting pretty good reviews. I run dirt king fab on mine. Definitely helped my caster numbers when I switched to them.
  12. Apr 17, 2016 at 8:01 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Got the winch mounted up today.
  13. Apr 17, 2016 at 8:04 PM
    FreidTaco
    FreidTaco boost
    jeff
  14. Apr 19, 2016 at 10:41 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Thinking of Ben and Timmy and Kevin. They went thru this area this morning.
  15. Apr 19, 2016 at 11:01 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    hopefully ben didnt have to get out and push the other truck like they do on the bikes.......also hope his front fender is surviving
  16. Apr 19, 2016 at 11:03 AM
    Digiratus
    Roaming the PNW
    The RedHead
    What's up with the front fender?
  17. Apr 19, 2016 at 11:06 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    His door flew open from wind and bent the shit out of the edge it shares with the door.
  18. Apr 19, 2016 at 11:07 AM
    Speedytech7
  19. Apr 19, 2016 at 11:08 AM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    That's pretty dang funny. Never heard of that happening.
  20. Apr 19, 2016 at 11:09 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Wow, that sucks.
