Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. May 30, 2016 at 8:56 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    No Ben, this is not correct. I can let go of the wheel and it goes perfectly straight down the highway.
    An interesting thought but not sure that is possible. :notsure:
    It is possible something happened internal to the rack tho or maybe a bent tie rod end. At first I thought it had slipped a tooth on the steering shaft splines. Again, not sure this is possible. I've never heard of either of these things happening to others but many 1st genners have taken to spot welding the splines I am referring to. I have not done this mod.
  2. May 30, 2016 at 9:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I know the rack can slip teeth. Was something on that on ttora.
    A bent tie rod would be visually obvious and the truck would be almost Undrivable as one side would be bent
  3. May 30, 2016 at 9:05 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I would also think the tires would be skewerd looking, like the toe was way out or something on the side that's bent. Not sayin the toe isn't the trouble, but looking at the tires, they seem to be pointing correctly.
  4. May 30, 2016 at 9:08 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Firestone lifetime alignments FTW. I have definitely gotten my monies worth from them. :rofl:
    Blackdawg[OP] likes this.
  5. May 30, 2016 at 9:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    God I wish I could do that
  6. May 30, 2016 at 9:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Didn't like the new top gear. Felt forced. Chris Evans is not great. Matt Leblanc was actually not bad. Everyone was not good though.
    Not a great start.
    because_wumbo-truck likes this.
  7. May 30, 2016 at 9:52 PM
    Digiratus
    Roaming the PNW
    The RedHead
    IMO, it was bound to fail anyway. There is no way it could ever measure up. The bar is set too high.
  8. May 30, 2016 at 9:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea way too high. Have to wait and see what Jeremy's new show has in store.
  9. May 30, 2016 at 11:03 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    It was terrible. I turned it off halfway through. I hate to say it but I'd rather watch American top gear any day and that used not to be my opinion. Times have changed.
  10. May 30, 2016 at 11:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haven't seen american top gear in years. It was awful
  11. May 31, 2016 at 12:03 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Agreed, the first season was rough. But when the British top gear fell apart, the US version really stepped up their game. Nothing beats Clarkson, Hammond and May
  12. May 31, 2016 at 12:12 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well it only fell apart last spring..couldn't have gotten that good since then haha
    I'll just wait for Jeremy's new show
  13. May 31, 2016 at 12:26 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Believe it or not, they've made leaps and bounds. And I absolutely hated Adam Ferrara back when he was doing stand up comedy. They copied the UK top gear too closely and had no chemistry, but now on their 4th or so season and they've made a good impression on me after boycothing the show for the last season or two. It still needs work, but massive improvement from the first season imho.
    I'm definately interested to see the Amazon prime show with the old top gear gang
  14. May 31, 2016 at 4:57 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    I thought that was the show you were talking about. That's the one I want to see.
  15. May 31, 2016 at 6:55 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh ha yea no, bbc kept top gear alive with all new format and cast. Wouldn't bother with it though.
    Jeremy's new show is call The Grand Tour. On Amazon prime only
  16. May 31, 2016 at 5:48 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Nice Ben! I've been toying with drawing something up myself. Although solidworks would probably be better than Acad which is what i have access to. Or i may just back of a napkin it haha. What are you thinking for axle setup? I've browsed jberry and boxrockets builds quite a bit. Its fun thinking about all the cool stuff you could build once you get decent with a welder.
  17. May 31, 2016 at 8:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Power is on a logarithmic scale here. You'd need 500w or more for 10x the range using power alone.
    That said. 5-15w is plenty with a great antenna tune.
    The leafs off your truck are way too long for a trailer.
  18. May 31, 2016 at 8:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No..no they won't.
  19. May 31, 2016 at 8:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha...yea...idk..good luck. That's a big and expensive project. I don't see your fab skills quiet being there but you'd get good fast. I hope.
    I don't even know what the fall trip is so maybe you have a shot
  20. May 31, 2016 at 8:25 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    When your trying to build a sweet trailer but your buddy doubts your fab skills
    mizzac and joshipps like this.
