Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Aug 31, 2016 at 9:38 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I can grind a washer down to size for you Mike, what thickness are you looking for?
  2. Aug 31, 2016 at 10:14 AM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Lol theres that. Thats why i have considered checking out the new 6.2 in the Chevy/GMC lots of power and from what I've heard better mileage then the 5.7 still. I've tested a few duramaxs and even powerstrokes.
  3. Aug 31, 2016 at 10:33 AM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    I drive a 2015 2500 duramax for work and average 18-19mpg... i get almost 600 miles per tank. And I'm only at 120,000 miles on it.
  4. Aug 31, 2016 at 10:36 AM
    Speedytech7
    My dad has the 6.2 in his Escalade and it actually gets decent mileage and makes great power. He's a lead foot so that says something.
  5. Aug 31, 2016 at 10:51 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Thanks Zane. Like maybe 3 or 4 mm or less I think.
    Monte referred to it a a shim, but I think later he was referring to making a whole new spacer to fill the gap. IIRC, the spacer he made originally is only a few mm small.
    @Blackdawg You are referring to how much that little sleeve in the alt bracket moved and was sticking out, correct? The one you had to 'press' back in so the stock alt would fit back into the mounting bracket.
  6. Aug 31, 2016 at 10:58 AM
    Speedytech7
    That pinch sleeve in the alt is supposed to take up the slack in a GM application, but maybe it is too small for where you're using it?
  7. Aug 31, 2016 at 11:00 AM
    Digiratus
    Roaming the PNW
    The RedHead
    :stirthepot:
    Overheating would not have been an issue because she would have been able to cool down while idling, waiting for Monte to give you a tug up some of those obstacles. :luvya:
    We did it in the easy direction. All of the challenging sections were on the downhill side of the pass. I think Ben, with his lack of a locker, would have really struggled in some of those steep, uphill sections.
    Blackdawg[QUOTED][OP] likes this.
  8. Aug 31, 2016 at 11:05 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Well it did take up the slack as far as I could tell. But if you have to return to stock as a trail fix, moving the sleeve back out of the way can be a challenge. I think the reason for a larger spacer or a shim is to make it easier to swap back to stock on the trail.
    Speedytech7[QUOTED] likes this.
  9. Aug 31, 2016 at 11:07 AM
    Speedytech7
    Makes sense if it will physically fit :thumbsup:
  10. Aug 31, 2016 at 11:13 AM
    Digiratus
    Roaming the PNW
    The RedHead
    That is easy for you to say now, but at the time you knew going back up would have been a real challenge for you.
  11. Aug 31, 2016 at 11:17 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Your guys' arguments always crack me up.
    Clearly the only solution here is to actually wheel a technical trail where Ben can find the limits of his rig and we can see if he's still over-confident. Shoshone wasn't that hard IMO.
    Blackdawg[OP] and Digiratus like this.
  12. Aug 31, 2016 at 11:35 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Ha. That is what Monte wanted. He wanted to go re-run the trail in the opposite direction. It definitely would have been more difficult in that direction. But too late now. It'll be a while before we return to Crowsnest.
    It is probably best tho that we didn't end up doing it at the time. Ben's tire was cut and we didn't know it at the time. Plus Monte's front diff was about to disintegrate.
    m3bassman likes this.
  13. Aug 31, 2016 at 12:38 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Ya I would like to test one, the 5.3 was decent, but felt pretty gutless honestly.
    Lol see if I could justify one I would get it just for better mileage on the highway heading back to Montana. And the longevity of the motor. Just save up and buy the exact trim and specs you want and keep it and just start saving for a side toy.
  14. Aug 31, 2016 at 3:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    A washer/shim is probably 1mm
    Yea. But remeber the bushing I cut to fill the gap for the GM one? Could cut a new on of those.
    For reals though..
    That's why I was coming to wheel with you at holy cross. :p
    Cause you wheel where a stock truck can go.
    And yes. I would have taken Igor everywhere we went this last trip. I'll probably never bring Frank again on a trip with you again. Just need tires and sliders and I would be plenty happy going where you go.
  15. Aug 31, 2016 at 3:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No Frank was a broken truck when I was winched in Colorado...
  16. Aug 31, 2016 at 4:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well yea but that was accidental.
    You probably would have turned around had it been you
  17. Aug 31, 2016 at 4:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not really considering a guy who's never taken a chance in his life with his rig and never once had a serious trail injury is trying to tell me his rig is superior because he has never take a risk with it ever or pushed it beyond its abilities or broken it to be put in the situation of do I go one or turn back?
    :luvya:
  18. Aug 31, 2016 at 4:54 PM
    Squeaky Penguin
    Brett
    I wheel more than you and harder trails than you and my rig doesn't break. Your argument in invalid.
    :luvya:
  19. Aug 31, 2016 at 5:26 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
  20. Aug 31, 2016 at 6:04 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
