Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Sep 6, 2016 at 8:26 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Owww, that suck big long donkey dicks. I'm a little worried about my rack too. It isn't holding the toe setting like it should.
    Yup, It was in there. It was near one end but since its heavier than the popcorn, it may have moved deeper in the tube.
    Was the tape job intact?
    IMO, gunmetal will look the best on the green or red for that matter. Not a fan of the copper. Too bright, too blinghey.
    PcBuilder14 likes this.
  2. Sep 6, 2016 at 8:27 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Long ones huh? Not like miniature donkey dicks? :rofl:
  3. Sep 6, 2016 at 8:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :brianr: could happen :notsure:
  4. Sep 6, 2016 at 8:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Huh I'll dig in the tube more.
    Really? I really dig the copper ones.
    https://www.tacomaworld.com/threads...y-bs-thread-thing.431255/page-3#post-12799288
    Looks amazing on the green
    SconnieHailer likes this.
  5. Sep 6, 2016 at 8:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's not bad.
    4 bolts and the tie rod ends and the hose lines and steering colum.
    Long as nothing is bent it shouldn't be bad. put some poly bushings in too while your at it.
    It's a pita don't get me wrong. But..you don't need anything special other then the 10mm wrench for brake lines
  6. Sep 6, 2016 at 8:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Unless you have a pit or a lift, its a shitty job, laying on your back and all. Sorta like pulling and replacing a front diff on a two track in the middle of the Ca wilderness. :rolleyes:
  7. Sep 6, 2016 at 8:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Name is escaping me too.
    Flare nut wrench!
  8. Sep 6, 2016 at 8:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea well that took 3 hours. Steering rack..no problem. Haha
  9. Sep 6, 2016 at 8:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, well, you wasted the first 45 minutes fucking with that CV. BTW, what is the secret to getting the birfield joint off the axle. Ever figure that out?
  10. Sep 6, 2016 at 8:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's true.
    And no I never looked at it.
    Also. I'm screwed on the two weeks of oct. Last week of weed spraying is the first week of oct and then going to Tippet for a week after that.
    Is it possible to move it to the last two weeks at all? :oops:
    Well glad it's not over heating. Use an air compressor with an barrel extension with 90° pin holes. What I ise on the utvs and atvs at work. Blows all kinds of shit out of radiators.
    The trailer. Will it ever get done haha
  11. Sep 6, 2016 at 8:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What are the dates?
  12. Sep 6, 2016 at 8:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    17-28th. :oops:
    I'm 85% Rock solid there. Still waiting on Mickey for total confirmation.
  13. Sep 6, 2016 at 9:07 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Dude, that sucks... Who's Mickey?
  14. Sep 6, 2016 at 9:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Tarp? Finish that shit. What winter is for.
    Yea I know :pout:
    Mickey is the guy that found me and contracted me for the summer at Tippet.
  15. Sep 6, 2016 at 9:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Regaurdless I want to do a two week trip then. Hoping devin can come with me to Tippet and then road trip after. That way we get a good three weeks together or more. She is moving to Maine at the end of September.
  16. Sep 6, 2016 at 9:15 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Are you still not sure if you will be working beyond the weed killing work? What day would that be? October 6th?
  17. Sep 6, 2016 at 9:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    6th is last day or weed killing.
    Depending on Mickey. Anywhere from the 7-15th I could be at Tippet. I don't know when exactly or for how long yet. Waiting to hear back hopefully tomorrow as he is traveling.
  18. Sep 6, 2016 at 9:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I think you need to tell me exactly before I go to my boss.
  19. Sep 6, 2016 at 9:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Okay. I will have dates for you tomorrow. :pray: this works out..
    Wait what. 17'' sport rims for your truck?? Or car..Cause...i haz 17'' sport trd wheels. Granted ill be using them until the SCS ones come
    Well..weld outside man. Man up! haha
  20. Sep 6, 2016 at 9:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Gotcha. Well surely there has to be some random 17s floating around locally for that.
