Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Sep 22, 2016 at 8:57 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I have drum weights too.
  2. Sep 22, 2016 at 9:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    JB weld would add more weight though
  3. Sep 22, 2016 at 9:08 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Wouldn't welds do the same?
  4. Sep 22, 2016 at 9:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You might be able to compensate by reducing the size of the weight.
    I've never used the stuff myself. Is it enough just to have a small amount between the two pieces or do you have to gob it on to ensure it will retain the weight?
  5. Sep 22, 2016 at 9:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sorta. But be closer as I drilled the center out.
    Probably have to use a lot.
  6. Sep 23, 2016 at 8:21 AM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    I got quoted 4550 with shocks to do a setup like this....
  7. Sep 23, 2016 at 10:51 AM
    SconnieHailer
    Marc
    Cantilever eh Jeff? That's a steal if it's good fab work... Though what's wrong with leafs? Cantilever is a bitch to valve and I haven't seen many that impress me performance wise in comparison to a DMZ leaf sprung setup.
  8. Sep 23, 2016 at 1:54 PM
    Member1Zillion
    Member1Zillion Involuntary Kamikaze Co-Pilot
    Big Whiskey, WY
    '01 TRD, '17 Tundra, '07 FJ Cruiser, 94 PU, '18 T4R, '84 PU
    This, that, & the other thing
    I've seen lots of these welded weights fall off of cars & trucks throughout the years. I doubt you'd ever notice a difference as most are less than 1/2 an ounce, unless you frequent the upper limits of the speedometer, which most Tacoma peeps do not.
    Blackdawg[OP] likes this.
  9. Sep 23, 2016 at 5:58 PM
    Explor
    Explor Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
    HTS-528 BRAZING ROD
    ^This would work , or some cast iron welding rod
    Like 1Zillion said .... Why bother ?
  10. Sep 23, 2016 at 7:50 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    @Blackdawg
    Those copper Ray 10s your pushing are growing on me. Wish he would do 16s.
    SconnieHailer likes this.
  11. Sep 24, 2016 at 6:20 AM
    FreidTaco
    FreidTaco boost
    jeff
    I want more
    i want more than 12" of travel out of the relocation that pelfrey has. I am not against leaves at all
    Also front lockers are pointless. Locks up just fine without
  12. Sep 24, 2016 at 6:59 AM
    SconnieHailer
    Marc
    I was suggesting the DMZ kit. That's more than what I've got by a bunch.
  13. Sep 24, 2016 at 9:48 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sweet. I said fuck it anyways.
    Yea I know..I feel like more people would be down if 16s where offered. But at this point Id be pissed if he did since I bought tires for 17s already for these wheels haha
    Go dmz then
    Plus you only have a +2 kit anyways right? Pelfrey kit would go with that perfectly.
    Just came off the big horns from hunting. Snowed 6-8" overnight and showed no signs of stopping. Freaking cold and wet. Hate that.
  14. Sep 24, 2016 at 10:01 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    I messeged him asking the availability of the bronze ones. I like those just as much. Copper would be cooler though. "Limited"
  15. Sep 24, 2016 at 10:02 AM
    SconnieHailer
    Marc
    Pelfreybilt no longer makes the kit anyways. Plus I think I'd want more rear end than I have now with a 2+ kit. It'd be close though.
    Yea this weather has me bummed out. Wanted to get up in the hills this weekend without getting soaked..
  16. Sep 24, 2016 at 10:05 AM
    SconnieHailer
    Marc
    I'd love the copper on the white truck. Tempted myself but I don't want 17's... I like having all the tire i can get.
  17. Sep 24, 2016 at 10:47 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea the bronze is nice too. Was a wait for those though too so said fuck it. Copper it is haha
    True. Idk I've been enjoying pulling the same numbers about front and rear.
    Still would like a better rear setup but broke..haha
    Yea not liking this weather either. The desert is super saturated. Flooding in places it looked like.
    Eh. Idk. I'm okay with it now. After having them on Igor seems fine. I still have more tire then I did before.
    15s are best still..haha
  18. Sep 24, 2016 at 10:54 AM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    Got some snow here last night
  19. Sep 24, 2016 at 10:58 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    Haven't heard back yet. How long is the wait? Months or weeks?
  20. Sep 24, 2016 at 11:03 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bronze I think was November for next shipment.
