Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Dec 14, 2016 at 4:27 PM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Nice man!
    Who'd you score a job with?
  2. Dec 14, 2016 at 5:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Thanks I'll check it out!
    The college. Well I work at the Whitney art center. Be I charge of all the tech stuff. So audio and lighting.
    joshipps[QUOTED] and Digiratus like this.
  3. Dec 14, 2016 at 8:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    man. Its like everyone is an adult now with no time to BS on TW anymore or something...
  4. Dec 14, 2016 at 8:21 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Can't talk, going to sleep so I can be up early for voluntary training in the morning!:rolleyes:
  5. Dec 14, 2016 at 8:33 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    I have certainly gotten busier but now its winter break. All I have to do is study for the GRE.
  6. Dec 14, 2016 at 8:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    GRE?
  7. Dec 14, 2016 at 8:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i swear to god im going to do that to Frank.
  8. Dec 14, 2016 at 8:52 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Graduate Record Examination. Most graduate schools require it so it's best to take it before or right after graduating undergrad while everything is pretty fresh. Scores are kept for 5 years so I can go work for a bit and then return for a masters or PhD.
  9. Dec 14, 2016 at 8:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh duh.
    Yea i should have taken it. Didn't think about it at the time. Oh well.
  10. Dec 14, 2016 at 8:59 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    It's not always required and it can certainly be waived. In the wildlife field you tend to just fall into positions where you can transition into a masters if you work enough tech jobs with universities. The exception would be the highly sought after schools. It's covered under my benefits otherwise I am not sure I would be doing it. I think it's $160 to take it...insane.
  11. Dec 14, 2016 at 9:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    All those type of test are crazy expensive. But wait until you see how much it cost to apply to Grad school. haha insane.
    I only want to go to MaGill if i do a masters. Doubt they would wave it.
  12. Dec 14, 2016 at 9:10 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I have seen the prices for the ones around here. No thanks!
  13. Dec 14, 2016 at 10:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    o_O
    Please don't black out Franks headlights.
  14. Dec 15, 2016 at 12:22 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. But yes to the 2jz swap
  15. Dec 15, 2016 at 7:05 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    what in the actual fuck? You...captain overland build a truck to the nuts, born and bred wyo boy...is moving to god foresaken LA?! Oh man good luck. The only way id move there is if somone offered me the dream job of the century, like a gear tester for a snowboard company or something.
  16. Dec 15, 2016 at 11:06 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not really. Torque curve is similar to the 5vzfe. But it doesn't peak out at 220. Haha
    And a v8 swap presents more issues.
    2jz is practically bolt on.
    Well. I'm moving there to pruse my dream job. Either there or London and try and get into Abby road
  17. Dec 15, 2016 at 12:25 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Damn. Glad you know exactly what you want! When do you move? Feb?
    Guess you're gonna inspire us to run the rubi soon since you'll be way closer
  18. Dec 15, 2016 at 12:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No I just took a interim job at the college in Sheridan. So more like the summer. Even fall maybe.
    Haha yea you bet! Though idk when I'll have Frank in la. So maybe not. Idk yet.
  19. Dec 15, 2016 at 12:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well depends on the race car now doesn't it?
    I'm not doing a body lift. So v8 is out. Your welcome to do it.
    And yea next year. Wanted to in February/March actually. But this job popped up which will let me save up money to make the move there easier.
    Only thing that make me stay is if Tippet comes around. And I seriously doubt that'll happen.
  20. Dec 15, 2016 at 12:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol do you ever read what i post...ever? haha
    No its in sheridan. Wyoming.
    just on the other side of the Big Horns. Where Josh lives and Gage lived for a while.
    Plenty are running the exact motor you and I have.
    But true trophy trucks are mid engine and custom built. Im not doing that. And you can't fit a V8 in our trucks without a body lift. Ive only seen only nicely built LSX swapped tacoma on here thats LT. But he bought it that way so wasn't helpful with how the motor fit.
    Plus after looking into LS motors it would be just as if not more expensive to get what i wanted.
    Idk why you're hating on the 2jz. I6 motors are torque monsters and yea for high hp its higher rpms but whats new there? Nothing. Before the supercharger i as at 4k all day going up some of the forest roads in passes just to keep going 30-40mph. Least with a 2jz at 4k i'll have up to twice the power so i don't see the issue.
