Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 1, 2017 at 1:26 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
  2. Jan 1, 2017 at 1:27 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    a whole lotta junk in that trunk
  3. Jan 1, 2017 at 1:32 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    But, but that camera though, I mean pssh I think you guys are missing the finesse he was going for there, $650 is a steal:cookiemonster:
    Blackdawg[OP] likes this.
  4. Jan 1, 2017 at 1:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    TAC weld mod on steering bushing. Supposed to tighten up steering a lot and get rid of wander and a rattle.
    Didn't really have any of those issues. But worth a shot. Pretty easy to do. I'm done. Just have to reinstall the column. Gonna wait as its very easy to access the brake booster and oedak right now haha
  5. Jan 1, 2017 at 7:44 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Happy new year guys! On our way back to WY from WI. 400 miles in by 9:30 :woot:
    Blackdawg[OP] and BossFoss like this.
  6. Jan 1, 2017 at 11:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Figured Id try it. Pretty easy to do really. It gets rid of slop in the steering so people say it helps with wandering.
    No poly bushings yet. I have some though to go in.
  7. Jan 1, 2017 at 12:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not my words. Others. Lots of people say this fixes it and drives completely different after doing it feeling more responsive and all.
    I have no idea yet.
    I do know that the joint can develop a lot of play in it. Mine didn't seem to have much. But I know some can.
    I think the play in the U joint is worse. But who knows. I'll find out soon enough.
  8. Jan 1, 2017 at 3:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It works.
    I haven't driven it. But I did a simple test. Before the mod. I wiggled the wheel back and forth in the zone where it does nothing. You know how you can jiggle it about a half inch or so.
    The wheels don't move at all though. You have to move the wheel past the play area to make them turn.
    Now. The wheels move inside the zone where they didn't before. Definitely tied things together much better.
    This is with stock rack bushings.
    Won't be driving it for a bit. Brakes need bled and alignment is Tuesday morning. I'll probably do the bushings as I have them and might as well. See how I feel tonight.
    Either way. It makes an obvious differnce. I've taken video too.
  9. Jan 1, 2017 at 3:43 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Under there is a captured spring, the spring is ultra stiff but allows some movement and ultimately the collapse of the column in the event of a serious crash. His welding stops the spring from doing its thing. Otherwise you'd be correct it would be useless for a splined connection.
  10. Jan 1, 2017 at 3:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I just wanted to try it. Wasn't complaining about my steering either. But if it winds up be good then I'm doing it to all the tacos at my place.
  11. Jan 1, 2017 at 5:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I will forever feel sorry for Igor and guilty for the three years of Missouri winter abuse.
    Broke a bolt taking off the skid. Damn.
  12. Jan 1, 2017 at 5:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's amazing how fast it happens. Sad too.
    And I didn't think Idaho salted roads
  13. Jan 1, 2017 at 5:30 PM
    Speedytech7
    WADOT started salting I-90 this year too, it's a major bummer
  14. Jan 1, 2017 at 5:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Just plows and dirt here. Thankfully
    Speedytech7[QUOTED] likes this.
  15. Jan 1, 2017 at 5:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    @SconnieHailer Marc, who do you think the packers would rather play next week? The Seahawks in Seattle or the Giants in NY? :)
    SconnieHailer likes this.
  16. Jan 1, 2017 at 5:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wasn't that bad I though.
    Mine got bad. Hopefully no more though.
  17. Jan 1, 2017 at 5:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Nothing in Wyo that comes even close I-90 in Wa. I think Wyo can get away with only sanding because traffic volumes are so low.
    I just drove back from Mazama, all sanding in all the treacherous spots until 1-90. All of the spinouts and ditchings (at least10 incidents) were in the sections that were sanded. On I-90, 10 times the traffic load and everyone is doing the speed limit or 5 over. I can see why they are salting I-90.
    m3bassman likes this.
  18. Jan 1, 2017 at 5:43 PM
    Speedytech7
    There's still rock salt sitting in the foglight cutout of our Escalade from when we drove back from South Dakota. They were laying that shit thick from Ritzville to Vantage
  19. Jan 1, 2017 at 5:45 PM
    justinf307
    justinf307 Well-Known Member
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    @Blackdawg
    Is your dad still happy with his ADS setup?
    Planning on calling for some quotes tomorrow, and after reading the entire ADS thread they're close to the top of my list.
  20. Jan 1, 2017 at 5:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Idk..i80 is pretty bad.
    Granted every year you see the large pile ups, it's usually i80 haha
    Loves it. Rides super good. Amazing actually considering we've never felt the need to revalve it.
    Should be at the top or near the top of your list. Amazing shocks. Going all ads on both mine when I can afford it.
