Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Feb 7, 2017 at 10:51 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    And he did it on a shock that could not be revalved. o_O
  2. Feb 7, 2017 at 10:52 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea. not ideal for sure in that regard. But he didn't mind it obviously.
  3. Feb 7, 2017 at 10:52 AM
    Digiratus
    Roaming the PNW
    The RedHead
    And you did it without charts and graphs. Genius!
    Blackdawg[QUOTED][OP] likes this.
  4. Feb 7, 2017 at 10:53 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Sounds interesting. I would love to see what you did.
  5. Feb 7, 2017 at 11:11 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea the biggest problem is the shock bodies themselves. You'll bottom out the shock before bottoming out the bump.
    Wheelers super bump kit or similar and the right amount of spacers would eliminate that though. And you'd gain down travel. At the loss of some up travel. So Net gain travel is minimal i'd say in stock locations. Its required to run 10s though if you have a lot of lift like Frank for instace. i had 8.5'' shocks and they were damn neat maxed out at ride height.
    How much the springs allow the wheel to go down is totally up to the springs. Shackles will affect that a lot too. Shackles do odd things though. And i'll admit im a tad wary to do shackles on 01-04s but Mike is doing good with his. Frank's shorter leafs like the longer shackles a lot.
    Squeaky Penguin likes this.
  6. Feb 7, 2017 at 11:14 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    When I say as outboard as possible I mean just inboard of the frame. Going 12"s with the top mount as close to the bed as possible, and the lower mount below the axle if need be. If you design your shock setup to work for the entire vertical travel of your springs, they'll also work for articulation. Not necessarily so the other way around.
    You gain downtravel and loose uptravel. Net effect zero most likely, and uptravel is more important IMO. Your main spring determines your travel numbers, and I doubt you'll even find a shock using the stock mounts and works in the usable level of travel of the spring.
  7. Feb 7, 2017 at 11:19 AM
    Squeaky Penguin
    Brett
    What your model fails to account for is that the distance between the stock shock mounts at full bump is less than the collapsed length of a 10" stroke shock. You can't really use all 10" of travel with the stock mounts.
  8. Feb 7, 2017 at 11:25 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh i gottcha. yea that is a great location if you can get the geometry right.
    SOA doesn't like vertical travel though is my point. You can get the axle to articulate more with flex then you can with just pure droop. If that makes sense. There isn't enough arch in SOA setups.
    This Ben.
    The mounts are too close.
  9. Feb 7, 2017 at 11:26 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea so instead of hitting the bump you'll be hitting the shock.
  10. Feb 7, 2017 at 11:29 AM
    Squeaky Penguin
    Brett
    This. Keep in mind the collapsed length of a typical 10" shock is around 16". My 10" short bodies are around 14" and may work better in the stock location. They're free once I take them off to whoever will follow through with this experiment.
    I've got some plans. :spy:
  11. Feb 7, 2017 at 11:34 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    HOLY FUCK!!! YESSSSS!!!!
    I just got the LED lights to work at the hall!!!! I AM SO STOKED!!! :goingcrazy:
    SconnieHailer likes this.
  12. Feb 7, 2017 at 11:36 AM
    Digiratus
    Roaming the PNW
    The RedHead
    One of two possibilities. Either your springs will be in negative arch or you will not have colapsed the shock fully. There will be exposed shaft.
  13. Feb 7, 2017 at 11:37 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Okay.
    So most 10'' shocks are 15'' long collapased and 25'' long extended.
    The distance between the stock mounts with the bumps in contact, lets say because i don't know off the top of my head, is 13''. This means that the 10'' shock with bottom out and you LOSE that 2'' of up travel. Yea you'd gain 2'' or 1.5'' over an 8-8.5'' shock of droop. But you loose up travel. So the Net gain of travel is like 1''.
    Unless you're like me and don't give a fuck then slowly kill the shocks.
    Shackles change this quite a bit though.
  14. Feb 7, 2017 at 11:50 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well again, other factors at play to consider as well. One being will your leafs droop that much to begin with and the shackles allow it. Then there is the ride height you'll be dealing with and if you'll be in the bumps most the time.
    Again, 10'' shocks work great if you have 4'' of lift. You kinda need to have 10s. But for like how Igor is and even your rig..10'' shocks would mean you'd probably have 1-2.5'' of up travel..which would ride insanely rough since even little bumps would slam the bumps.
    You want to try and get your ride height in the middle of your shocks regardless of how long they are. Generally speaking. This way you have the up travel to cope with bumps and down travel to cope with holes.
  15. Feb 7, 2017 at 11:53 AM
    Squeaky Penguin
    Brett
    14.21" collapsed and 24.31" extended. Still need to find the distance between the stock mounts and full bump (which will differ based on your springs) to be able to get a informative answer.
    All this discussion and you guys arguing over a couple inches of droop doesn't make a bit of difference for what you do with your trucks. Up travel is where you'll see improvements in ride and performance doing anything faster than a couple miles an hour. I would never sacrifice uptravel for down.
    Blackdawg[OP] likes this.
  16. Feb 7, 2017 at 11:54 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Exactly. Up travel is where it's at.
    Crawlers love the droop.
    I have about 6'' of up travel on Frank.
    like 2'' on Igor
    Both truck have Super bumps and Franks have taller spacers....guess which ones rides better...
  17. Feb 7, 2017 at 12:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    wtf..the first PN says 7.9'' the second is 8.6'' haha almost an inch different.
    Droop would be a touch more but not a lot.
    And you need to buy a new locker? Thought you fixed it.
  18. Feb 7, 2017 at 12:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    A new Toyota unit is cheaper? Wow.
    And they are different because the passenger side stock mount is smaller. Due to the gas tank and it's forward angle. Most are .5" different though not 1"
  19. Feb 7, 2017 at 12:20 PM
    Squeaky Penguin
    Brett
    The stock mounts are different distances side to side. Just another reason why it makes no sense to use them when trying to maximize travel.
  20. Feb 7, 2017 at 1:18 PM
    Justrom
    Justrom Well-Known Member
    County 10 - Wyoming
    '13 Dbl Cab Long Bed
    The WEMT course is a great one if you're serious about emergency medicine. It is a 30 day long course and comes with a lot of continuing education (like any EMT), so unless you're working with an ambulance service or volunteer Fire rescue squad it can be hard to keep your certification current.
    The Wilderness First Responder (WFR) is a 10 day course that provides a really solid fundamental understanding of first aid and treatment in a remote environment. It is the standard for guides, trip leaders, etc. who lead groups in the wilderness. You still have to recertify every two years, but there are less continuing education requirements.
    Wilderness First Aid (WFA) is a first aid course that goes beyond the Red Cross "hold my beer and call 911!" response. It teaches a lot of how to improvise and prioritize the basic first aid treatment when the ambulance won't be there in just a couple minutes. It's a great course for anyone who spends time outside of city limits.
    There are a handful of courses offered in Wyoming, several in Lander, and in Laramie. Outside of Wyoming, REI is one of the biggest sponsors of WFA courses, on any given weekend especially in the spring they're probably running 6 to 10 courses around the US.
    I was raised in Whitehall, about an hour west of Bozeman on I-90.
