Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Feb 12, 2017 at 10:35 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Those pesky dish hinges, makes a guy want to punch a baby.
  2. Feb 12, 2017 at 11:58 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hey. Use whatever the hell you want man. Just do it.
    Above Ellensburg?? When? FTnB? There is no way you wont that. I beat Brett and he had 4.88s and a manaul..barely beat him. Really it was even.
    :rofl:
    I laughed so hard at this haha
  3. Feb 12, 2017 at 12:02 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I've been a locksmith for almost 30 years. When I started, Graphite was the lubricant of choice. And it worked well.
    WD-40 has been around since the 50's, and still widely used. But as I said, it really doesn't stick around too long.
    Graphite is really not used all that much anymore in the field, but new factory lock cylinders still come with a light coating of it, because it doesn't bleed away or dry up while sitting on the shelf or in shipping.
    In the interest of speed and making money, spray lubes are 1st choice. And they work better at cleaning crap than a dry lube will. WD-40 works great for quickly and efficiently cleaning the interior of locksets and linkages. But it doesn't stick around long and attracts the dirt back for some reason.
    When Tri-Flow hit the market, with the ptfe stuff, locksmith's gave a collective cheer.
    It has staying power and the money making potential from this stuff alone is unparalleled. I buy it by the case and use it daily.
    Sorry for the dissertation, just wanted you to know where I was coming from with recommending it. With all that being said, if you really want it to last, use light grade white lithium grease. That's what it came with from the factory.
    SconnieHailer and m3bassman like this.
  4. Feb 12, 2017 at 12:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well i almost got some graphite spray for its. Figured it would work best as that's what ive used on locks.
    I use triflow next time. Like i said before, if i get a year out of the wd40 i'll be happy. it is easy enough to to do this.
    Deathbysnusnu[QUOTED] likes this.
  5. Feb 12, 2017 at 12:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also i think the only time ive used triflow was when Mike sprayed my UCAs with it. And they squeaked like hell AFTER he sprayed them. Never have otherwise. Eventually went away thank god...Have never have squeaks from my LT kit other then that one time.
    Or what was that stuff mike? @Digiratus
  6. Feb 12, 2017 at 12:46 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I use tri-flo liquid in the little black bottle. Makes my UCAS squeak some times but I also get more miles than most out of my uni balls so it clearly works
    Digiratus and Deathbysnusnu like this.
  7. Feb 12, 2017 at 1:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i couldn't say what his were. I know our where very dirty so i asked if i could. And they squeaked like hell after that. went a way of course but thought it was odd.
  8. Feb 12, 2017 at 2:47 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Auto correct. Great comedian
    Blackdawg[QUOTED][OP] likes this.
  9. Feb 12, 2017 at 4:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    No way. You are remembering incorrectly. I beat you. Not by much but you were out front. Who's Brett? :popcorn:
    It was a teflon spray lube from Dupont. PTFE. Same stuff as Tri-Flow except it in an aerosol dispenser.
    https://www.amazon.com/dp/B002HYXAO...TF8&colid=1P5D39KHH5V3M&coliid=I11TFH7T9V3BNE
  10. Feb 12, 2017 at 5:12 PM
    Explor
    Explor Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
    :thumbsup: Tri-Flow , FTW !!
  11. Feb 12, 2017 at 6:31 PM
    SconnieHailer
    Marc
    Soooo my family knows I'm a yota freak because Jen got a Tacoma onezie at the baby shower... Lol! Thanks Ryan and Julie!
  12. Feb 12, 2017 at 7:12 PM
    SjTacoSharks
    SjTacoSharks Well-Known Member
    Larry
    Boise, Idaho
    09 DCSB SR5 Sport
    Did you take that picture with a potato?
  13. Feb 12, 2017 at 7:14 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Moving to an HTC, nice you'll like it!
  14. Feb 12, 2017 at 8:23 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Best option out there is PB blaster. Stuff is amazing on rusted nuts. Also im pretty sure you can hit your target about a quarter mile away with that spray tip.
  15. Feb 12, 2017 at 8:24 PM
    SconnieHailer
    Marc
    I've had Motorola phones for the last 5+ years. With a droid turbo now and very happy. Analog antenna is good and it's not a gargantuan size... Jen has a nexus and hates the shit out of it. Super shatty software.
  16. Feb 12, 2017 at 8:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Squeaky. There is a video somewhere of that funny race.
    HA! Love it.
    That stuff is okay. i like the flavor but doesn't have the the same kick or texture of mikes or just all around goodness.
    Digiratus[QUOTED] likes this.
  17. Feb 12, 2017 at 8:29 PM
    SconnieHailer
    Marc
    Lol @ the fridge decision.
    Yea hell with nexus garbage. Stay away.
    Happy with my Moto and will continue to run them as they just work with no frills attached. Software updates always work as described and I've never wished the camera was better.
  18. Feb 12, 2017 at 8:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wuss haha
    i love it hot. This years batch was delicious.
    Speedytech7 likes this.
  19. Feb 12, 2017 at 8:54 PM
    Digiratus
    Roaming the PNW
    The RedHead
    the ones in glass jars have been cooked in the jar for shelf life. Unfortunately, that thanges the flavors. Try to find one on the refrigerated isles. The fresh ones are always better IMO.
    Be careful with that. When I was shopping for an unlocked phone, I found they aren't always truly unlocked. meaning, unlocked phones do not work on all networks. For instance, there was no HTC10 that was capable of working on both sprint's network and on verizon's network.
    I knew you were confused.
    Mr Penguin wasn't with us in Ellensburg/WaBDR. No, the race I am referring to included you, me and timmy. Timmy shot out way ahead early and then just sped off because he knew he had no chance. Leaving you and I to battle.
    You lost. It is unfortunate, there is no video of this one.
    He knows. I hooked himm up. :cool:
    It's fresh man. No Preservatives of any kind. 30 days and its done. Flavor changes after that.
  20. Feb 12, 2017 at 8:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't think this is true.
    REMATCH! :D
