Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Feb 22, 2017 at 8:49 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    swapped the scs over to the t4r
    took it for a drive, tundra calipers clunking inside.
    nice..
    swapped em back
    fun way to burn a couple hours this evening.
  2. Feb 22, 2017 at 8:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Really? Why? I plan on doing thing very slow and clean. No short cuts here.
    wait really? You sure? tell Vin this. He has designed all his wheels to clear those.
    you sir, are a hypocritical failure..haha
  3. Feb 22, 2017 at 8:55 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I mean I went slow but after you take a few second gen headlights apart you would understand. Then to see one fog up 5 months later and do it again. The top he cutoff settings were a pita. Any recommendations on single row light bars?
  4. Feb 22, 2017 at 9:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    How wide?
    And i took my dads apart. 2nd gen lights are a bitch as they are full sealed. Read an ingenious idea to add a small silicone packet behind the shroud. Pretty smart. Did you add more glue from TRS? The cut offs should be set..you just re aim the headlight which is just stock screw adjustments..
  5. Feb 22, 2017 at 9:03 PM
    Bennett707
    Oregon
    there was a clunk noise coming from both sides when i applied the brakes.
  6. Feb 22, 2017 at 9:03 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    lol I've done a full set trust me I know. Ya I re sealed with the trs butyl. First time when I painted and let them sit for 7 days when I backed them together the paint off gas hazed my lens. So I got a new set of cheapie and swapped the lens. I did the packet in the back also. When u put them through make sure u test them on the truck then jb weld the fuck out of the nut behind or else they will move some. Idk I'm just not that blown away with them. Stock and a bhlm would of been fine
    Blackdawg[QUOTED][OP] likes this.
  7. Feb 22, 2017 at 9:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    But not when you weren't? That..is odd. Only the wheels changed? Fine without the SCS wheels..
  8. Feb 22, 2017 at 9:06 PM
    Bennett707
    Oregon
    running 17" tundra wheels w/ 1.25 spacers now
    put scs w/ 3/4" spacers
    clunk clunk clunk
    didn't visually look like it was touching
  9. Feb 22, 2017 at 9:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Hey man, a couple of questions about that ferry ride.
    Looks like you stopped over in Juneau. How long was the layover? Did you have to switch ferries there?
    I read that it is possible to put up a tent in a designated area on the boat instead of paying for a stateroom. I am curious if you had access to your truck down in the vehicle hold during the cruise? If we did it, we have RTTs. Would we be allowed to use them? Is there enough ceiling room in the hold to open them up?
    Your trip looks amazing. I would love to visit places like McCarthy. Truly the end of the road.
  10. Feb 22, 2017 at 9:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    that doesn't sound right man..
  11. Feb 22, 2017 at 9:23 PM
    Bennett707
    Oregon
    went away when i switched everything back :boom:
  12. Feb 22, 2017 at 9:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    wtf. that is...odd man. Did you try the wheels without spacers? or with the spidertraxx ones? Taco is fine?
  13. Feb 22, 2017 at 9:26 PM
    Justrom
    Justrom Well-Known Member
    County 10 - Wyoming
    '13 Dbl Cab Long Bed
    - We could have continued to Haines on the same ship, but we decided to spend a day exploring Juneau since we were already there. We camped there one night and caught another ferry the next morning. It was cool and worth the time.
    - You can access the car deck a couple times a day, but no access except during designated times so the RTT is not an option. People put ground tents on the back deck, bring lots of duct tape to secure it down though because it can get windy. Lots of other people just roll out their sleeping bag in the lounges, solarium, movie room, etc. It is common and acceptable not a "dirt bag" thing at all. You have to pack your stuff up by a set time so the room can be used for its normal purpose and you can't set up again until a designated time at night. There are lockers and public showers for people traveling this way. People stake their territory pretty early on and occupy it until it is time to get off.
    We coughed up for a stateroom to give our 4 year old son a place to relax and maintain his sleep schedule. It was pricey, but worth it for us to maintain sanity.
    McCarthy was awesome, the camping picture I posted earlier with the tent and awning out was taken near there. We would go back there again in a second.
    Digiratus[QUOTED] likes this.
  14. Feb 22, 2017 at 9:27 PM
    Bennett707
    Oregon
    put the boras on w/ the scs t4r. didnt' drive the taco w/ the 17s.
  15. Feb 22, 2017 at 9:30 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Bet a wheel weight was hitting
  16. Feb 22, 2017 at 9:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Too bad about the RTT use. Sounds awesome otherwise.
  17. Feb 22, 2017 at 9:39 PM
    Bennett707
    Oregon
    ahhhhhh didnt even think about that
  18. Feb 22, 2017 at 9:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ahhh yes good thinking
  19. Feb 22, 2017 at 9:41 PM
    AWilson013
    AWilson013 Almighty Dirt King
    Alex
    Seattle, WA
    2006 GX 470 Sport
    Matte Grey SCS F5s - 255/80R17 ST Maxx - Front Runner Slimline II - CVT Tent/Awning - 35w Morimoto HID Low Beams - LED High Beams - LED Fogs - AFE Dry Filter - BP-51s - Dirt King UCAs
    Are you sure it was the front? There's not a ton of room between the rear shock mount (upper) and the tire. That's the only reason I was running spacers.
  20. Feb 22, 2017 at 9:41 PM
    Bennett707
    Oregon
    well i'm not putting them back on.
    i really didnt like the tundra rims on the taco
