Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Feb 23, 2017 at 11:16 AM
    rwickesbeg
    rwickesbeg Active Member
    Rich
    West Yellowstone, MT
    2008 Blue Tacoma TRD Off Road
    2inch OME Heavy Duty Suspension...ARB Front Winch Bumper...
    Auto, No sliders on yet. 265/75/16 bfg ko2....Been on the trails in northern Wisconsin. No real rock experiance
  2. Feb 23, 2017 at 11:19 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    hmm..you'll probably want sliders. There is a rather rocky section in the middle after the switchbacks and with that tire size could be interesting. Might be okay though. But been a while since ive been there and im sure it's only gotten rougher.
    Morrison is not a trail to start on either. You'll want to be very comfortable with your rig and its abilities. Trail is pretty dangerous if you loose focus or make a small mistake things can go bad in a hurry on the switchbacks.
  3. Feb 23, 2017 at 11:23 AM
    rwickesbeg
    Rich
    Yes I have heard the switch backs are very dangerous. Thanks for the input....What trails would you recommended near the park
  4. Feb 23, 2017 at 11:27 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The best area is by Cooke City. You'll have a blast around those old mining roads and Goose Lake Trail is there too and also amazing and fun.
    Not familiar with the ID side or north MT side. But otherwise you'll have come a ways out of the park.
    rwickesbeg[QUOTED] likes this.
  5. Feb 23, 2017 at 12:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No im talking about the 5.3L All Aluminum one. Its still an LS1
  6. Feb 23, 2017 at 1:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    what? No.. its not an LS3
    L33
    "The Vortec 5300 L33 (VIN code "B") is an aluminum block version of the LM7, and was referred to as the Vortec 5300 HO in marketing materials. However it should be noted that the L33 uses a flat top piston from the 4.8L instead of the standard dish piston found in the LM7. It also uses 799 cylinder heads, which are identical to the 243 casting found on the LS6 and LS2 with the exception to the Corvette spec valve springs, and hollow stem exhaust valves on the 2002-2004 LS6. This combination increased the compression from 9.5:1 to 10.0:1. The L33 also had a specific camshaft not shared with any other engine, with lobe lift of 7.2 mm, 193 degrees of intake and exhaust duration, and a 116 degree lobe separation angle. As a result, power increased by 15 hp (11 kW), to 310 hp (230 kW) and 335 lb·ft (441 N·m). It was only available on extended cab 4WD pickup trucks. Only 25% of trucks made in 2005 had the L33 engine."
    LM7
    "The Vortec 5300 LM7 (VIN code 8th digit "T") was introduced in 1999, and can be considered the "garden variety" version of the Generation III V8s.
    The 1999 LM7 engine produced 270 hp (201 kW) and 315 lb·ft of torque (427 N·m).
    The 2000-2003 engines made 285 hp (213 kW) and 325 lb·ft (441 N·m).
    The 2004-2007 engines made 295 hp and 335 lb·ft of torque, it has a cast iron block and aluminum heads.
    The stock cam specs @ .050 duration are: 190/191 duration, .466/.457 lift, 114 LSA, 112/116 Timing"
    and again
    5.3 L
    The Vortec 5300, or LM7/L59/LM4, is a V8 truck engine. It is a longer-stroked (by 9 mm (0.35 in)) version of the Vortec 4800 and replaced the L31. L59 denoted a flexible fuel version of the standard fuel LM7 engine. Displacement is 5.3 L (5,328 cc (325.1 cu in)) from 3.78-inch (96 mm) bore and 3.622-inch (92.0 mm) stroke. Vortec 5300s are built in St. Catharines, Ontario and Romulus, Michigan. Another engine variant, the L33, shares the same displacement, but has an aluminum block with cast in cylinder liners, much like the LS1."
    The L33 is literally just an aluminum version of the LM7.
  7. Feb 23, 2017 at 1:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    And again..
    "The 4.8 L and the 5.3 L are smaller truck versions of the LS1 and were designed to replace the 305 and the 350 in trucks. Both the 4.8 L and the 5.3 L share the same engine block, heads (upper end) and as they share architecture, some parts interchange freely between these engines and other variants in the LS family."
  8. Feb 23, 2017 at 1:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Believe it or not. I want it to save weight :anonymous: ha
    Its more expensive then a normal 5.3L generally. But usually can be had for 4-800 bucks.
  9. Feb 23, 2017 at 1:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea the iron block is much stronger. But I think i'd just Cam it and put better heads on it then tune it. Should put it over 400hp. Then if i get to it, i'll turbo it for low boost to get it over 500 to 600. Be PLENTY i'm sure haha
  10. Feb 23, 2017 at 2:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thats true. Probably get done with it and be totally good with it.
  11. Feb 23, 2017 at 2:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea at this rate. I think i'll do the motor swap next. Get that dialed in and working well. Be a ton of work. Then work on 4 link rear/cage/engine cage after that. That way i can play while having the bigger motor and save up for the other shit.
    I'll probably guy a motor and just go ahead and tear it open, check it, and do cams and head work while its out. Can't hurt and i won't want to do it after its sitting happy in the truck.
    I'll probably need to go down to 4.10s or 4.30s or 4.56s ha on Grimm Jeeper calculator with 4.10s and 35s with the NV4500 and all 1st gear is lower then my current setup. But 5th is taller by a lot.
    Just saying that out loud sounds nice...but damn...shit load of work and money. Wish i could start now..haha
  12. Feb 23, 2017 at 2:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    im confused..please tell me you didn't buy this turbo for your truck..haha
    And true..
  13. Feb 23, 2017 at 2:56 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    plz tell me thats for the brz...its off a saab
  14. Feb 23, 2017 at 2:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I hope not. Tiny thing.
  15. Feb 23, 2017 at 3:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    and here is a guy who won't buy new coil overs for his cherished offroad rig..
    but would pour money into making a shitty rear mount turbo for his shitty dodge POS with a turbo that is too small for his car...
    :der:
  16. Feb 23, 2017 at 3:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no. It wouldn't be cheap.
    There is literally no form of cheap boost.
    none
    ever
    period.
  17. Feb 23, 2017 at 3:20 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    *Cough cough Ahem...
  18. Feb 23, 2017 at 3:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :rofl:
    careful..you're likely to blow a gasket with that bad boy
  19. Feb 23, 2017 at 3:27 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Man I tell you what, best $12.89 I ever did spend. Definitely need to cage the vehicle you install it on though. Whole nother animal after the install.
    Blackdawg[QUOTED][OP] likes this.
  20. Feb 23, 2017 at 3:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I bet it rips your face off.
