Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 15, 2017 at 9:19 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Nope, just waiting on HR now. I will be offered the Lander position and they understand if I take the Cottonwood position if it gets exempt from the freeze. Pretty much taking whatever gives me a final offer as both jobs are awesome.
  2. Mar 16, 2017 at 9:58 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    If your replacing the ball joint, back the nut to the top of bolt (or put a new nut on) in case it ruins it and give it a smack with the hammer. Think it also helps to support the lower control arm so it's not binding.
  3. Mar 16, 2017 at 11:42 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    When I put mine in. I just had my friend ty use a pry fork and then I tapped up on the uca arm with a rubber mallet. Maybe ask ur lady to give it a few swings
    BabyTaco likes this.
  4. Mar 16, 2017 at 12:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Getting the ubj out of the uca was the easy part iirc. It was getting it out of the sprindle that was the challenge.
  5. Mar 16, 2017 at 12:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If it was me, knowing what I know now, i'd just pull it all off the truck and do the work on a bench.
  6. Mar 16, 2017 at 12:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    yes
  7. Mar 16, 2017 at 12:39 PM
    BossFoss
    Wyoming
    01 DC Tacoma
  8. Mar 16, 2017 at 1:15 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Ur taking the uca off right? So u just need to take the bolt out and undo the ball joint castle but from the spindle. Or are they different than second gens?
  9. Mar 16, 2017 at 3:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Here is a stolen generic pic but is shows where Ben is stuck.
    I had to laugh a little bit at this pic. You can see where someone has been pounding on the UCA trying to get the UCA off the BJ stud.
  10. Mar 16, 2017 at 3:39 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Ha weird it's upside down compared tot he second gen. My ball joint is pressed into the uca and the spindle has the castle nut. That's sucks! Must of changed a few and decided there was a better way.
  11. Mar 16, 2017 at 4:43 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Using these was the only way I could get my upper ball joint out of the spindle. Tightened one down as much as I could without it slipping off, then hit that flat spot on the spindle a couple of times with a hammer. Popped right out.
    https://www.amazon.com/gp/product/B000NPUKB6/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
  12. Mar 16, 2017 at 4:46 PM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    BossFoss likes this.
  13. Mar 16, 2017 at 4:54 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    I'd buy it if it was a Subaru Impreza
  14. Mar 16, 2017 at 4:57 PM
    joshipps
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    It can be if you squint really hard and wear headphones with boxer rumble playing while you drive it?
  15. Mar 16, 2017 at 5:37 PM
    PcBuilder14
    Brent
    Nor Cal
  16. Mar 16, 2017 at 5:40 PM
    joshipps
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Hey, it's been 4 weeks alright?!
  17. Mar 16, 2017 at 6:31 PM
    Justrom
    Justrom Well-Known Member
    County 10 - Wyoming
    '13 Dbl Cab Long Bed
    NOT MINE - Wasn't someone looking for housing in Laramie? Might be cheaper than rent :ballchain:
    Up for sale my 1991 International School Bus converted to an RV, it has an
    International DT Turbo Engine. This is basically a great clean slate of a bus
    with solid insulation, that can be customized and easily modified. The bus
    is well insulated with blue foam board, and an extra layer of ceiling
    insulation. I lived in it for 5 years in Laramie, even through the winters. It
    has a wood stove for heat, and in the summer I install a cooler unit where
    the stove pipe usually runs.
    See photos at: https://wyoming.craigslist.org/rvs/6009769921.html
    Speedytech7 likes this.
  18. Mar 16, 2017 at 9:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Don't bother with the 3-jaw unless you need it to get the UCA off the UBJ. There isn't enough lip availble to grab the edges.
    A kit like this stands a much better chance of getting the UBJ outa the spindle. And no need to buy them. Vatozone will have a loaner you can use.
  19. Mar 17, 2017 at 9:35 AM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    PB Blaster and put nut back on so edge of nut is flush with bolt face. Get your mini sledge out and beat it like that birch owes you money.
  20. Mar 17, 2017 at 9:50 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Ben just cut the balljoint off you aren't reusing it or the arm so why waste time separating it. Even if you still want to separate it after, it will be easier when it's not in the wheel well.
    Digiratus likes this.
