Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 20, 2017 at 8:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  2. Mar 20, 2017 at 9:07 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    u ever think of welding up a skid plate? i did mine and its like 50 bucks and the same design as all the others. except my oil drain whole is a little bigger bc i wanted my hand to fit in there
  3. Mar 20, 2017 at 9:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well..if it makes you feel any better his are 295/70r16s or whatever...soooo may be okay? haha
    You're line???? I'm sorry..i forgot who spotted you up that on the correct line..
    :luvya:
  4. Mar 20, 2017 at 9:31 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Lol who knows. Maybe he will chime in and let me know the deets. @Squeaky Penguin
  5. Mar 20, 2017 at 9:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Couldn't? Or didn't due to loosing an entire wheel just 200 yards before...
    You're argument is invalid.
    Im surprised he hasn't already honestly haha
    But think he goes to bed semi early.
  6. Mar 20, 2017 at 9:33 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    you have a locker, youre just too afraid to crawl in the dirt to lock it, ill do it for you when i do mine at the trail head
    and i also have zero skids save for the front one, youll be fine
    SjTacoSharks likes this.
  7. Mar 20, 2017 at 9:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    hahahahahaha
    I miss you. lol
    And you also have 1.5'' more ground clearance than him.
  8. Mar 20, 2017 at 9:43 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    lame
  9. Mar 20, 2017 at 9:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah totally forgot about it..college will do that to you.
    But i didn't know 10mins after that it would hold on 3 bolts.
    He doesn't do hardcore...anything haha
  10. Mar 20, 2017 at 9:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    neither is mine. Do all and do it well is and has been my goal.
    Also you didn't shoot anything with your 10mm did you this last go?
  11. Mar 20, 2017 at 10:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This must be the 40th time I heard this 'discussion' about poukeepsie with who did what with what. Aren't you two tired of it yet? :tumbleweed:
  12. Mar 20, 2017 at 10:02 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I don't think the 10mm works on the 5D. :rolleyes:
  13. Mar 20, 2017 at 10:03 PM
    Speedytech7
    I thought he was referring to a firearm.
  14. Mar 20, 2017 at 10:04 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That would be a 9mm.
  15. Mar 20, 2017 at 10:06 PM
    Speedytech7
    That makes much more sense, I could only come up with a handful of them that take a 10mm slug and I doubted Ben would own any out of that list.
  16. Mar 20, 2017 at 10:07 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i dont know what you define as hard core crawler...like will you do any trails with me lol?
  17. Mar 20, 2017 at 10:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I am. But its the only thing he thinks he can rub in my face :rolleyes:
    probably not..haha he doesn't like any kind of rock bigger than football these days it seems..haha
  18. Mar 21, 2017 at 6:02 AM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Practical me will go with 33x12.50's
    Impractical me wants 35's
    Blackdawg[OP] likes this.
  19. Mar 21, 2017 at 7:11 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I have 295/75r16, just a touch taller but the same width:
    You'll be fine as long as you're prepared for a lot of cutting and smashing.
  20. Mar 21, 2017 at 8:33 AM
    Digiratus
    Roaming the PNW
    The RedHead
    with quite a bit more sidewall to work with. :thumbsup:
